Question about Lexmark P6350 All-In-One InkJet Printer
Lexmark p6350 all-in-one not working
My lexmark p6350 all-in-one not working,because when i installing drivers,this massage appears-----usb device not of the usb devices attached to this computer has malfuctioned and does not recognize it.for assistance in solving this problem,click this massage.
  • 71 Answers
I am guessing that you're using the New improved windows Vista. If so, you need disconnect the printer power and usb connection. then remove the current driver for the printer and down load the current driver @:
The soft ware will tell you when to install the printer
Posted on Jan 27, 2008
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
Hello! I turn on the printer with USB data cable atached to my pc and the Ready led is on. I installed the printer driver from lexmark support site everything beeing ok until now. I try to print from my...
Please try to switch to another usb port or try using a different usb cable. try to unplug and replug the cable and check if the computer was able to detect the printer.
For further assistance please contact Lexmark Technical Support
Aug 06, 2011 | Lexmark E321 Laser Printer
I just bought a new Gateway NV53 laptop but my P4350 Lexmark all in one printer does not recognize any of the USB ports.
Did you check whether the USB ports are recognizing other USB devices such as Microvault or Flash Drive? If all other USB devices are recognized except the Printer, then reinstall the USB Drivers. You can uninstall the USB drivers from the Device Manager and restart the Computer. The USB Devices are listed under Universal Serial Bus Controllers in the Device Manager.
Jul 10, 2010 | Lexmark P4350 All-In-One InkJet Printer
After new installation,usb2.0 is not recognize
Dear sir,
This problem is motherboard driver is not install properly
Aug 26, 2009 | Intel D845WN (KD845WNPAK10) Motherboard
Windows does not recognize USB connection to the SpeedStream 6520- malfanctioning
try using different USB port. if the it is unknown device. means the machine didn't recognized the device. you may have to install the device driver. (windows is a funny thing).
Nov 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Problem with hp laser jet 1018
i need the windows xp driver
Jul 12, 2008 | HP LaserJet 1018 Printer
Lexmark P6350 and New Imac intel compatibility
I'm part way there.  I rang Lexmark and they say P6350 can only work with Mac OS up to 10.4 whereas I'm using 10.5.2.  I'm not yet fully convinced it can't be made to work and a knowledgeable friend will be round later.  I may get back to you. Porphyry
Feb 22, 2008 | Lexmark P6350 All-In-One InkJet Printer
Lexmark P6350 All-In-One InkJet Printer Logo
126 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
