Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Pip not working
I try to use my Pip and it just stays black
    Problem Solver:
  • 11 Answers
That set has 2 tuners ..try using a splitter and putting signal on both. I'm working on this model now..it has a noisey color wheel motor. PIP will work from either tuner.
Posted on Feb 08, 2008
There a black block in the mddle of tv when you chage channel
hi do you have pip on this tv, if so press the pip on the remote to remove it ,if this don't work try the info button on the remote hope it works
regards
shaun
Jan 25, 2014 | Vizio E701i-A3
PIP won't work
PIP is probably set to an input with nothing connected.
Feb 03, 2013 | Hitachi 65T500 65" Rear Projection...
My picture in picture isn't working?
Most of these sets have two tuners--one for main and one for PIP.
If main picture works fine but PIP is bad or Green? either the PIP tuner or the PIP board is bad---these were known to have the PIP have problems but it was more rare than their sets made before it.
SD TECH
Apr 26, 2012 | Mitsubishi WS-55315 55" Rear Projection...
The tv on;y shows a small pip window in color if it is a large picture the picture is in black and white how to fix?
Whatever input video signal you're using, PIP should be in color. What are you using out of your dvd for the second video input source, composite or component? Composite you should always have color, Component, if you have a bad red or blue, and just the green is working, you will get black and white. The green is the luminence signal.
Nov 23, 2011 | Televison & Video
I have a Mitsubishi Big Screen TV that is about 20 years old. There seems to be a problem with the PIP. The entire middle of the TV screen goes black, you can see the outside edge of the program in the...
i have the solution. common problem. it has a pip module with defective (leaky) capacitors. they are surface mount capcitors. mcm has a mitsubishi pip module repair kit order number 32-11755 $14.95. 1800 543-4330 customer service 1877626-3532. www. mcminone.com
Nov 15, 2009 | Televison & Video
Mitsubishi VS-6017R PIP
VS-60-17r
Unit warmed up slowly, then took several times to stay on, not it will not stay on. Guessing power supply capacitor.
Jul 17, 2008 | Televison & Video
Pip for my iQB36B44w
The PIP may only work with an external tuner or source (VCR, DVD, CATV box, etc) If your TV doesnt say "dual tuner" then you need an external source for the PIP (Use a VCR and its tuner for instance)
Feb 13, 2008 | Zenith B27A11Z 27" TV
Black Box?
my tv was working fine. somebody hit the menu button on the tv or the remote and i get the black box appearing in the middle of the screen. and also the pip is staying on my tv it keeps showing "a snowy picture of pip sjpwomg channels 2 through 18 i cannot figure out how to get this off of my screen.
Feb 08, 2008 | Panasonic PT-51HX41 51" Rear Projection...
60" Mitsubishi Problems
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Dec 04, 2007 | Mitsubishi VS-60611 60" Rear Projection...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
