Home | Canon | PowerShot A620 Digital Camera | How will i unlock a mem...
Canon PowerShot A620 Digital Camera
Problem for Canon PowerShot A620 Digital Camera
How will i unlock a memory card in SD 790 IS canon
By muanag_feuda on Oct 22, 2009
how will i unlock a memory card in SD 790 IS canon camera
Best Solution
posted on Oct 22, 2009
Helpful)
Obertelli
Rank: Guru  Cameras & Camcorders  Expert
Rating: 94%, 290 votes
All SD (and SDHC) cards have a locking switch on them and this can be activated accidentally when handling the SD card.
Remove the SD card and slide the switch on it away from the lock position. If this does not work or if the switch is already in the correct position, then slide it all the way to lock and then fully back again.
If this fails then you have a faulty SD card and must replace it. Dirty electrical contacts do not result in a card locked message so you won't have to worry about those but as with all memory cards never touch the contacts unless they clearly need cleaning. Note that if you have to replace the memory card you can use regular SD cards up to 4GB and SDHC cards which start at 4Gb rising to 16GB maximum. The camera slows down when using SDHC above 8GB though.
I hope that you have found my answer to be of use and in return I ask only that you rate my answer.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" my memory card is still not working it is really faulty i have to replace it maybe it the computer of the photoshop is really dirty " - muanag_feuda
Popular Solutions for Canon PowerShot A620 Digital
Questions and Unsolved Problems for Canon PowerShot A620 Digital
Do you recommend Canon PowerShot A620 Digital Camera?
Answer
Answer
My camera has a white speck of dirt underneath the first lens, and does interfere in pictures and... (More)
Answer
camera used in light rain, flash banged and quit, works otherwise is it possible to fix myself with... (More)
Answer
the date stamp is turned off and on the menu screen I cannot scroll down to the date stamp to check... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A620 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
