Autodesk AutoCAD 2005 Logo
Posted on Oct 22, 2009
Unable to execute the tool. The specified
AutoCAD LT 2005 - English SP 1.
Error message:
"Unable to execute the tool. The specified procedure could not be found."
Anonymous
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Mar 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
6774
Points
17
LT cads has limitations compare to original CAD 2005.. Some operations may nt work
How can I fix Riso HC5500 error code S03-201?
  • Code: S03
  • Description:
  • Belt platen lock
  • Causes:
  • The belt platen elevation mechanism cannot be set properly.
    200 S03 Transfer belt motor timeout The motor shaft encoder of the transfer belt motor does not attain the specified pulse count within the specified time. The required movement does not complete even when the transfer belt motor operates for the specified interval. 201 S03 Transfer belt unit sensor error The three sensors that determine the position of the belt platen produced an abnormal detection result. 231 S03 Belt platen operation error The upper limit position sensor fails to activate when the belt platen rises. 240 S03 Belt platen operation error The upper limit position sensor fails to deactivate when the belt platen lowers. 241 S03 Belt platen operation error The lower limit position sensor fails to activate when the belt platen lowers. 242 S03 Belt platen operation error The lower limit position sensor fails to deactivate when the belt platen rises. 243 S03 Belt platen operation error The vacuum positioning sensor fails to activate when the belt platen operates. 244 S03 Belt platen operation error The vacuum positioning sensor fails to deactivate when the belt platen operates.
  • Remedy:<>Reset power, or execute [Clear error] in Test mode. <>Some errors (such as PCB disconnection) may not be cleared by executing [Clear error]. <>Even if an S error occurs, it may be possible to continue operations using another unit. Therefore, certain error types require a specific reset procedure (described in Error Point).
Take it in for service, or replace all the sensors if you can find them for sale.
https://www.google.com/search?q=Riso+HC5500+error+code+S03-201
How Can I Obtain the Serial Number of a Modular Switch?
Obtaining the Chassis Serial Number · On a standalone switch:
Log in to the switch through Telnet or the console interface, and then run the display elabel backplane command in the user view to view electronic label information. In the command output, the BarCode field indicates the chassis serial number.
<Quidway> display elabel backplane
Info: It is executing, please wait...
[BackPlane_1]
/$[ArchivesInfo Version]
/$ArchivesInfoVersion=3.0
[Board Properties]
BoardType=EH02BAKKBarCode=2102113089P0BB000881
Item=02113089
· In a CSS:
Log in to the master switch through Telnet or the console interface, and then run the display elabel backplane chassischassis-id command (chassis-id specifies the CSS ID of a member chassis) in the user view to view electronic label information. In the command output, the BarCode field indicates the serial number of the specified chassis.
<Quidway> display elabel backplane chassis ?
INTEGER<1-2> Chassis ID
<Quidway> display elabel backplane chassis 2
[BackPlane_2]
[Board Properties]
Item=02113549
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the chassis ID according to the help information.
Obtaining the Serial Number of a Card Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a card. In the command output, the BarCode field indicates the serial number of the card.
<Quidway> display elabel ?
<1-1> The present chassis
backplane Backplane
brief Display information briefly
<Quidway> display elabel 1/?
<4,6-8> <CMU1>
<FAN1-FAN2> <PWR1-PWR2>
<Quidway> display elabel 1/6 brief
[Slot_6]
/$[Board Integration Version]
/$BoardIntegrationVersion=3.0
[Main_Board]
[Board Properties]
BoardType=ET1D2S08SX1EBarCode=020LVF6TBB000043
Item=03020LVF
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the slot ID according to the help information.
Obtaining the Serial Number of a Power Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a power module. In the command output, the SN field indicates the serial number of the power module.
backplane Backplane
<5,8,13,16> <CMU1>
<FAN1-FAN5> <PWR1-PWR4>
<Quidway> display elabel 1/PWR1
[Slot_21]
[Main_Board]
DATE=13_02_08 SN=A664A0212080086V0.9A
NOTE:
Obtaining the Serial Number of a Fan Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a fan module. In the command output, the BarCode field indicates the serial number of the fan module.
backplane Backplane
<5,8,13,16> <CMU1>
<Quidway> display elabel 1/FAN2
[Slot_18]
[Main_Board]
[Board Properties]
BoardType=LE02FCMC BarCode=2103010JTF0123456789
Item=02120995
NOTE:
2answers
E000602-0003
Problem with hard disc
2helpful
Hi there, I am building a java application which will call to praat for some execution of sound. I managed to call and sendpraat to praat from java application by java runtime.exec() But the praat seem to...
I was able to solve this problem..........
My java code is following........
String[] sendpraatCom = new String[3];
sendpraatCom[0] = "./sendpraat";
sendpraatCom[1] = "praat";
sendpraatCom[2] = "execute " + "<filename.praat>";
Runtime run = Runtime.getRuntime();
run.exec(sendpraatCom);
Now it is working properly.......
Dileepa sisila chandrasekera.
Department of Computer Science and Engineering
University of Moratuwa
Sri Lanka......
Apr 02, 2011 • Praat
Error in installation of "klog" and "dap91"
re install the accelerator plus. because when installing some files will missed dude to that install again and select the proper next button and agree terms and conditions. it will automatically any repair option wil come select the command if it not came automatically it will run.
1helpful
AutoCAD LT 2008 (xref circular references)
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
Top Autodesk Computers & Internet Experts
Ngoro
k24674
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
