Question about Brother MFC-5440CN All-In-One InkJet Printer
How to connect brother MFC-5440CN to Bt voyager 2091
I have connected BT Voyager 2091 for wireless mails etc. I would like to print via this router.
How do set this up?
Paul
  • 832 Answers
Connect machine to lan. Run the network drivers. PC should find the mfc.
In case you have to do some settings have a look into the network manual which is a pdf document on installcd.
When questions left go to brother homepage of your country and search your mfc and then the faq for networking answers.
Posted on Dec 31, 2007
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Wifi connection to BT Home Hub problems
Make sure you do not have any third party software running in your taskbar that deals with wifi connection if your trying to use the windows connection. this is what i do. its better, and more simple. Home Hub does not work well with non BT software. If your not sure, turn any wifi connection software off. i.e if any came with your wifi device. and then click on the start button. and click connect to on the right lower side of the start menu. You can use almost any wifi device with these devices. your best bet would be to let windows try to connect to your home hub. Also are you typing in your WEP key. correctly. How far away from the hub is the wifi device. Is windows wireless zero configuration off in system services. unliekly. but worth a look. I have had a home hub for three years and i have to admit they are a nuisence. The BT Voyager wifi works ver well. just in case there is some kind of incompatibility with your device, i highly doubt it though. Good Luck.
Apr 27, 2009 | Archos 705 WiFi Digital Media Player
I have just signed up to bt braodband and got a bt home hub. As a result I have a spare BT voyager 54g wireless network modem. Can I use this to print wirelessly to my lexmark printer
You can't use wireless adapter to hook printer to wireless network. You need a wireless print server. Example is Linksys or DLink Wireless-G PrintServer.
Jan 10, 2009 | Computers & Internet
Cannot connect my laptop to BT Voyager
Hi It sounds like your key is hexadecimal 64 bit (this would be 10 figures (either letters or numbers). The usual authentication modes are WPA or WEP. I would try both. If one is OK you'll be connected.
Dec 30, 2008 | Computers & Internet
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its 192.168.1.245 and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its 193.168.1.1
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
BT Voyager 2091 Wireless ADSL Router - DROP OUT
If you face frequent drop outs confirm with your isp that it's not a problem with line...and also check the physical setup of broadband check if your router is connected to main socket of your house where telephone line enters in your house......
now when you face drop outs check on your hard wired comp whether you remain connected or not if no its a problem with line..
if no reconfig your bt router for wireless network change the channel of your wireless network either to 1 or 11...
or either there is one other way reset your router to default settings by pressing the pin at the back of your router..
and after that your router will start its default wireless network i.e a unsecure network..
try connecting to that network if still the same there are drop outs it's a problem with router....contact bt to config the router...
Oct 01, 2007 | Computers & Internet
HELP PLEASE
You need to sign up to the ps3 wireless play just like xbox live but without paying. go to the sony website to find all the info.
Sep 13, 2007 | Sony Playstation 3 (PS3) Console
Brother MFC-5440CN All-In-One InkJet Printer Logo
151 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
