Question about Sewing Machines
Needle breaking, hitting bobbin case
I got a piece of material jammed in the bobbin case(I was working with the bobbin case open) and it pulled the bobbin case out of alignment so the needle breaks every time it goes down. Any way to fix it on my own?
  • 1 more comment
  • Anonymous Jun 25, 2008
    I think I have the same problem. I have a Brother xl 2600. I kept breaking needles and it looks like the hit the metal plate. I took it apart to clean. I took out the bobbin case to clean under it and put it back. I put everything back together and tried to sew again. We now it still wants to hit on the back of the needle and the bobbin thread gets all tangled up. What did I do and how do I fix it. HELP PLEASE!
  • Raggin Jun 25, 2008
  • dangordon53 Feb 07, 2009
    Sewing - needle hitting plate Singer 221k, I need to know how to realign the sewing needle shaft.
    Dan Gordon
    dangordon53@yahoo.com
    Problem Solver:
  • 10 Answers
I had this problem and it is very easy to fix!
With mine I looked at it for about half an hour, and all I needed to do was put the bobbin case back in,(how it fits normally) and then hold it and turn it anti clockwise until it clicks, it may be quite pressured to do but ive heard a lot of people having this problem and thats all that needed doing!
Hope i helped! :)
Posted on Oct 28, 2010
  • medellinprop Mar 12, 2011
    I live in Medellin Colombia. Three trips to the authorized Brother dealer and they couldn't fix it correctly. Now it works perfectly. Thank you.
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
loosen the needle clamp screw then you can pull the needle out with pliers not damaging any of the machine or bobbin area .
Oct 30, 2015 | Singer Sewing Machines
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
Why doesn't the machine pick up the bobbin?
You may have fuzz in your bobbin case or under the plate. If you have canned air, spray it out. Are you using a pre-wound bobbin or one you wound yourself. I've found pre-wounds to be the best. Make sure your thread is pulled thru the bobbin case correctly and your needle up top is threaded correctly too. It's real easy to miss either one. Also, be sure to use a good backing when using fuzzy fabric. What size needle are you using. Too small of a needle may cause this also. For standard embroidery or sewing usually use an 11. Hope maybe this will help. Kindest regards,
Jody
Apr 20, 2015 | Singer Quantum XL-1000 Computerized Sewing...
How do i stop the needle from breaking?
One of the most common causes of needle breaking is you are pulling your fabric to fast through. Let the feed dog do the work. When fabric is pulled it bends the needle backwards and then the needle hits the plate...breaks.
Feb 24, 2015 | Sewing Machines
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
Handwheel is locked down
Several things to check. Did the needle break and jam in the bottom? Is the needle bent or did it jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom cut the threads until you can free the hoop and material. Check the bobbin for pieces of thread and fuzz. Check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping and will cause a jam which means the handwheel locks.
Sep 23, 2013 | Brother PE770 Computerized Sewing Machine
The needle keeps breaking in my Yamata FY 910
The bobbin case rests on the lip of the hook and is is held into place by the position bracket. The position bracket is located at about 5 o'clock and has a small square end with a buffer spring. It must be positioned to hold the bobbin case securely and also allow the thread to pass through freely. It may be out of adjustment but may not.
If the bobbin case has turned, it is very likely to have suffered damage as it is made of a soft carbon fiber material. It not polished off, these damaged areas can snag the thread and jam the machine and create tension problems. Some gouges, burrs and needle punctures can be carefully sanded but you may need a new bobbin case. Use a 1500 grit sandpaper to smooth off the rough edges.
Jun 16, 2009 | Yamata FY910
Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
Mar 21, 2009 | Husqvarna Viking 1
Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Feb 25, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Apr 22, 2007 | Singer 7466 Mechanical Sewing Machine
Sewing Machines Logo
512 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
