When I turn on my TV it switches to standby mode within few seconds. This happened after I did some selection by pressing the Menu Button in the remote control accidentally.
SOURCE: 14" Tv/vid combi
If the light blinks it indicates a fault, probably in the high voltage circuit. If it is steady the problem could be anywhere. First you need to check all internal fuses. Then power supply for all necessary voltages. If this checks out each section would have to be isolated. At this point a service manual would be helpful (www.servicemanuals.net). From there it would be a matter of a process of elimination. Everything I said is contingent upon you being familiar with and capable of doing the work. These things are dangerous and best left to professioals if you are not trained. Good luck.
SOURCE: tv stuck in standby
I believe these Sony TV's have a built in obsolesence and Sony does not care about fixing them. I don't think a 7-year old TV is an "old model". Who can afford to by an expensive TV every 7 years. Shame on Sony.
SOURCE: would like to switch tv mode to cable mode
go to the menu button,press it, in menu service you to choice either air or cable. then select the cable
SOURCE: When i switch on my
Is your TV still under warranty? This problem seems common on this site with the Panasonic brand. I really can't say what exactly is causing this problem, but it seems like something in the power circuit board is faulty. My advice would be to call Panasonic's Technical Support Hotline and speak to a Technician. It could even be a problem that has warranted a recall of that particular model. The number for Panasonic's Hotline is 1-800-211-7262. Or, you can contact them via e-mail @ www.panasonic.com under "Get Support". Hope this helps...
SOURCE: Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
