Question about Archos 605 Digital Media Player
Recording video failure
When i try to record from sky it starts to record then a message appears saying rec shutting down.
I have just encoutered this problems. its worked ok before but in the last few days its shuts down. If I find a solution will let you know. Not very happy with my archos at the moment
Posted on Jan 14, 2008
  • boro shaz Jan 16, 2008
    just found a brill forum who solved my problem. take it out of the dock and make sure it is fully switched off not just in suspend mode then put back in the dock. Mine worked first time. Added the weblink to the forum below, excellent for solving problems
    http://forum.archosfans.com/viewforum.ph...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
How to record message for the answering machine
There should be a button on the base labeled greet or record(maybe rec).Press and hold down rec(greet if there is no rec) and it should prompt you to record or just beep.After it beeps record your message and let go of the button.Usually it automatically plays it back so you can hear it.Good luck!
Aug 06, 2010 | Motorola Mobility MD4260-2 Twin Cordless...
Cannot set up voicemail on a Binatone 1210 DECT
Please follow the below mentioned process:
1)press menu
2)press up/down to tam
3)press ok
4)It will say play(press ok to play messages), or press up/down till delete all
5)press ok it will say confirm
6)press ok this will delete all messages. If you want to record your own message follow steps 1 to 3 then 4)up/down till ANS MODE press ok,
7)scroll up/down it will say, ANS ONLY or ANS + REC,
8)select ANS + REC, press ok,
9)it will now say PERSONALIS(your own personal message) or PREDIFINED(standard answerphone message), select PERSONALIS press ok 8)now it will say PLAY MSG scroll up/down it will also say RECORD MSG, press ok hold phone to your ear till you hear a beep, record your personal message then press ok, if you go back to step
10) you can hear your message.
In normal mode, Press and hold 0 key to turn on/off answerphone and your personal message will be on.
To delete messages press 2 key for 2 seconds as messages are played press 6 to delete, you can delete messages before or as they are playing without listening to whole message.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 17, 2009 | Lands Phones
How do i connect a dvd recorder. to my sky box and t.v
Take the main aerial into the dvd,then a flylead out of the dvd into the tv.Connect a scart lead into av1 onthe dvd and then into the tv.If you want to rec from sky connect scart lead from sky into av2 on the dvd,when you want to record select av2 on the dvd as this is the channel to record the sky on.Hope this helps
Sep 08, 2009 | Televison & Video
I want to leave my own answering message on my voicemail, how do I do that?
Press Menu. Then the unit will say "record outgoing message" Press the REC/Memo button and the unit will say "recording" and beep. The display will start counting in seconds. Speak your message. Press the play/stop button to stop recording the message will be played back to you.
Sep 22, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
My new RCA Model 25205RE1-1 1815MO does not want to record a OGA. It appears to be recording as it so states and counts the seconds as you are speaking. I press EXIT and the OGA is not played...
The RCA Manual in incorrect. Step 8 reads "Press Set/Save to start recording. Speak within 6 inches away from the Mic located under SPEAKER button." Step 9 reads "Press EXIT to stop recording." Step 10 reads "The OGA is played automatically for your verification. It will then return to the OGA REC menu to start over or to record another OGA."
Step 9 should read "Press Set/Save to stop recording and the OGA is played automatically for your verification."
Step 10 should read "Press EXIT if recording is acceptable. Press Set/Save if you want to re-record."
By following the Manual you never save your message. "Playback" always has the Default message that comes on the machine. Furthermore, Customer Service at 310-953-9028 doesn't have a clue.
Jul 01, 2008 | RCA Lands Phones
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Archos 605 Digital Media Player Logo
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
