Question about Samsung HLR5067WX 50" Rear Projection HDTV
Losing picture color on TV
I have owned a DLP TV for about two years. The Screen will flicker and I will lose color. Do I need a new bulb?
  • Anonymous Mar 29, 2014
    changed bulb now picture is flickering
  • 87 Answers
Screen flicker can also be a bad dynamic black unit. Do you hear a low pitch growl when it flickers?
Posted on Jan 25, 2008
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
After about an hour or so watching the tv the screen starts to flicker. I just changed the bulb, thats seems to have delayed the problem. Any advice?
Is there any noise associated with the times that the unit flickers? Samsungs are notorious for losing the color wheel. I have replaced many and they usually make a high pitched whining sound. It could be high enough of a frequency that you may not hear it. If the lamp is new and the old lamp did not shatter or short out before you changed it I would say that the ballast is fine and I would change the color wheel. You will have to at some point as this is the weak point with the Samsung units. I have at tip at which will walk you through the process as well as identify places to purchase the parts at the best price.
Thank you for using FixYa and for the great rating. Great ratings help keep experts solving everyone's problems. Thank you.
Nov 13, 2010 | Samsung SP50L6HX 50" DLP HDTV
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
RCA HD52W59 Screen Flickers
This not a DLP set and does not have a bulb that the customer can replace.
It may need a firmware upgrade if avaiable.
Oct 21, 2008 | RCA HD52W59 HDTV Projection Television
Flickering and freezing of picture for a split second
The most likely problem for image problems and flickering is the lamp (23311083A). I found it at for about $180. Hope this helps.
Nov 11, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
506 people viewed this question
Jerry Greenberg
Jerry Greenberg
