Question about Mitsubishi WT-42315 42" TV
Mitsubishi WT-A42 Will not turn on - green light comes on for 3-4 seconds then goes off. When I press "MENU" and "INPUT" simultaneously to get the trouble code it blinks 2 and 2. Any help is appreciated! Paul.
  • 4 more comments
  • Basai Jan 20, 2008
    Well, I broke down and called the tech! The problem was with the "convergence" components. he fixed the problem in half an hour (and $239). The technician says is is a common problem for our TVs when they are over 4 years old - mine just turned 4 this month. Sorry I wasn't more helpful but good luck with your set...
  • Danover Jan 19, 2009
    While watching tv, it just turned off. Now, the power light comes on for 3-4 seconds, but turns back off without the screen displaying anything. Best Buy said "maybe" a bulb, but could be a board.
    Danny Overstreet
    danny.overstreet@gmail.com
  • Anonymous Mar 14, 2009
    I am currently experiencing the same problem. The "Geek Squad" guy diagnosed it over the phone and said they don't make parts for this repair any longer. Does that sound reasonable?
  • pcg3 Mar 31, 2009
    "i have a mitsubishi HD1030 recently i went to turn it on and it shut right off, if
    you try again right away you get the same result "turn off", what can i do? or
    what you think it is?
  • drummer Mark May 24, 2009
    I had the same problem about 8 - 10 months ago. My brother has the 55" inch Mitsubishi model with the same problem. The tech fixed my problem, cleaned the projectors and other components. It cost me approx. $240 for the pick-up, service repair, and return of the TV. Now, today, the TV is doing the same thing again. I believe I am going to cut my losses....repair it and sale it. I don't want to spend $240 -$250 every 8 - 10 months. I will never buy another Mitsubishi piece of junk ever again. I use to swear by the Mitsubishi brand....going to get myself a Sony....or anything instead of a Mitsubishi.
  • etalkishere May 11, 2010
    Hi Paul any update on this problem? Did you get it fixed? I similar problem. When I pressed Input and Menu simultaneously, however, I didn't see anything displayed on screen.
    Thx.
    Peter
I repaired a convergence problem on this model by locating IC8C01 and IC8C02, the two large convergence chips on the main pcb(center board) and solder all the leads making sure not to leave any solder bridges! The unit was over 4 years old and used often. Those chips get pretty heated and make the solder brittle and crack around the leads.
Posted on Jun 09, 2009
I finally called a tech. He came, took a look in just few minutes, told me it was the convergence, charged me $50+tax, estimated total cost of $350+tax ($50 trip cost could apply for total cost). I decided not to fix, wait for few days and decide. These guys are a rip-off.
I wonder if I can fix by myself. Where can I buy the convergence components or the whole module. I am not a technician, but wonder if my engineering background could qualify me for a self repair. I probably have to buy some soldering equipment from RadioShack?
Any feedbacks would be much appreciated.
Peter
Posted on Jan 22, 2008
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
TV Doesn't stay on...
HI
base in your comments in your TV you have defective power oscillation circuit! and need to diagnose your TV with a qualified technician! now if you have knowlegde in electronic trouble shooting i can give you the method to fixed your TV. Thanks in Advance!!!
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi tv will not stay on
That model has a blink code to help diagnosis. When the TV goes off press The Input And Menu Buttons On The Front Panel Simultaneously And Hold Them In For 5 Seconds After 5 Seconds The Power Led On The Front Panel Will Blink A Two Digit Sequence. It will help determine the circuit but troubleshooting will be needed to check for a defective component.
Mar 06, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi model WT-A42
maybe theres aproblem between the power supply and in the horizontal circuit of your tv
Jul 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
2-2 code
convergance ic are bad:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 02, 2007 | Mitsubishi WT-46809 46" Rear Projection...
TV Shutdown
Mitsubishi's have an error code system (press both menu and input/device buttons on the front panel, the green light will flash a 2-digit code...(example one flash short pause two flashes=12 long pause then it will repeat four more times...error 12 is no problem found...the other codes are 21,22,23 and 24.........Good Luck.
Sep 26, 2007 | Televison & Video
Mitsubishi WT-42315 42" TV Logo
1,513 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
