Question about Acer Aspire 5610-4648 Notebook
Acer 5610z screen
Screen flashes intermittently. also images go blurry and lines appear across the screen. when the laptop is opened and closed, the problem is solved on some occasions but not usually. have to keep on re-booting the notebook to get rid of problem for a while but not permanently.
  • Anonymous Jan 01, 2008
    I have the same problem. When you boot up the notebook, sometimes it's just all fuzzy and blurry and you can't read it and at other times, it boots up normally. Mine is a 5610-4648 notebook also. I'm wondering if there's a defect in manufacturing.
  • 62 Answers
There are a number of possible problems.
When the computer is turned on and you wiggle the LCD back and forth and the video becomes corrupted and then if you wiggle it some more and get it to work correclty then you either have a loose video cable connection or a defective video cable. In some cases the LCD will need to be replaced.
If this is not the case then there is the possibility that the video card is bad.
Posted on Dec 30, 2007
How to brighten screen of laptop acer aspire 5610z without keybord ?
May be there is any facility in control panel depends upon the video driver
Jul 20, 2012 | Acer Aspire One PC Notebook
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
Sep 29, 2009 | Acer Aspire 5610-4648 Notebook
Bluetooth button does'nt light up any more and i cant find the driver for it on acers support site for the 5610z
This is Acer Support home page,
http://gd.panam.acer.com/home/
1.In the box under the heading -> Select Product Family, click on Notebook.
2.In the next box that comes up, Select Product Line, click on Aspire.
3.In the next box, Select Product Model, scroll it down to 5610z, and click on 5610z.
4.There's your Bluetooth driver.
5.Click on the orange square icon with a Down Arrow in it, to the left of the Bluetooth file name.
A small window will come up.
6.If the empty circle to the left of ->Save File, does not have a green dot in it, click on this empty circle. Now go below and click on OK.
After you download the driver, it will be saved to your desktop screen, if you do not have your downloads set, to go to your My Documents folder. You may want to write down the driver file name, before you click on OK.
In either your My Documents folder, or if it is on your desktop screen, double-click on the file to open it.
Now follow the Installation Wizard.
After you're done, close all windows until you are back to your desktop screen. Now restart your computer.
Sep 01, 2009 | Acer Aspire 5610-4648 Notebook
ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
Ihave an acer 9410Z laptop the backlight won't
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Mar 11, 2009 | Acer Aspire 3000 Notebook
Fix Acer Aspire 5610z Laptop Screen
you need a new screen!!! www.computereworld.com I can fix this for $170 total, that is a new screen and the labor. submit a request on my site, or call me 662-549-2362
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Hp Pavilion dv2000 LCD Problems
Doubt that it's the inverter. Sounds more like one end of the LCD cable has been knocked loose. You might wan to check those.
Best of luck
Nov 15, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen keeps flashing intermittently.
Dec 30, 2007 | Acer Aspire 5610-4648 Notebook
Lines appearing on camera and images
Chwck the Samsung website -technical Support team -especially if this is a recent purchase. But generally speaking this is a no repair situation.
Jun 11, 2007 | Samsung Digimax V50 Digital Camera
Acer Aspire 5610-4648 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
