Question about Acer Aspire 5610-4648 Notebook
Screen keeps flashing intermittently.
Screen flashes intermittently and images go blurry. when i open and close the laptop, it will help the problem sometimes but not always. will then have to do about 10 restarts to solve problem
  • Becks Yaman Jan 03, 2008
    thanks for the advice. the notebook is still under warranty so will take it back to have it looked at.
  • 62 Answers
There are a number of possible problems.
When the computer is turned on and you wiggle the LCD back and forth and the video becomes corrupted and then if you wiggle it some more and get it to work correclty then you either have a loose video cable connection or a defective video cable. In some cases the LCD will need to be replaced.
If this is not the case then there is the possibility that the video card is bad.
Posted on Dec 30, 2007
  • James Girard
    James Girard Jan 03, 2008
    Thanks for the feedback, if possible I could use a "Fix Ya" rating for this support session.
    Happy New Year!
My computer keeps flashing the blue lights on and off,screen blank,not coming on tried to take battery off hold down start button connect to ac nothing happens same problem
Sounds like video card or video cable is faulty or loose. Is screen always blank no matter what you try? Were you getting intermittent screen flickering. There is a ribbon cable that runs from base to lid that sometimes get worn or loose from constant open/close of the lid. Try cranking lid to different positions while trying to boot up. You maybe able to find a video card under one of the covers on bottom. push card all the way inward to make sure it is seated correctly.
Dec 02, 2010 | Computers & Internet
Blurry image with movement in the shot
This is common under low-light photography where the shutter needs to remain open longer.
A few tricks to help:
- Use the flash. Enable the fill-flash. This will work if the subject is close enough to the camera.
- Manually set the ISO to a higher number. Use the lowest number that yields good results as higher ISOs tend to also introduce some "noise" or graininess to the images. The higher ISOs will increase the sesitivty to light and compensating with a faster shutter speed. This is usually the easiest way.
- Manually increase the shutter speed. Try speeds starting at 1/250th of a second or faster as needed. Refer to your camera manual.
- Another technique is to pan with the movement. For example: If a person is running, follow them with the camera and carefully squeze the shutter release butten avoiding any camera shake. This can keep them in focus and blur the background instead. This is very cool, but takes some practice to master. The images look amazing and it is worth the effort.
Hope these tips help.
-Tor
Feb 06, 2010 | Canon Cameras
Blurry image without flash
A blurry image when the flash is not used usually means that you move when snapping the picture. The flash helps you because the duration is so short, it freezes your motion.
Jan 19, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Sony KP51HW40
your convergence is trying to go out
Aug 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Acer 5610z screen
Dec 30, 2007 | Acer Aspire 5610-4648 Notebook
Shooting with External Flash
Without more information, it sounds like the flash may be set to a manual mode. Try setting the flash to an auto mode. The display should indicate something to the effect of "E-TTL" or maybe just "TTL". The reason your images are blurry, would be due to a slow shutter speed being used on the camera. If your flash is not set to trigger automatically, then the camera will use the slowest shutter speed to acheive the proper exposure of the image. My assumption would be that if you were to take two images back-to-back with the speedlight set to your current setting, one with the speedlight the other with the pop-up flash, the latter would not be blurry. Hope this helps.
Dec 07, 2007 | Canon Digital Rebel / EOS-300D Digital...
Indoor flash images are blurry
It is possible you have the Flash Mode set to one of the Slow Sync modes (lighting bolt with the word Slow). Slow synchronization flash sets a slow shutter speed for the background exposure and fires the flash for the subject exposure. Since the shutter speed is slow, your subject should be still and the camera should be on a tripod otherwise blur can result. Since this mode should only be used when the above conditions can be met, you should use the FILL-IN FLASH (single lighting bolt symbol) mode for most situations that require a flash for correct exposure. Repeatedly pressing the FLASH MODE button will cycle through the various flash mode settings.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Flash images are blurry
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Acer Aspire 5610-4648 Notebook Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
