Question about Samsung HP-P4271 42 in. HD-Ready Plasma Television
Samsung 42" TV
When off the tv clicks and the screen glows for a short while then returns to normal but works fine when on
  • 93 Answers
SOURCE: Samsung 42" Plasma HPT4254
You need to either call Samsung if it is under warranty or get a TV repair guy for you.It is a common defective problem i have seemed from Samsung,but usually it happened within the firs 30 days.
Posted on Nov 11, 2008
  • 30 Answers
SOURCE: Whenpower is applied, TV clicks on and off, no picture.
there probably is ive had a similar problem i just opened mine up and replaced the power board fixed it but i dont at all recommend fixing your own tv take it to a pro :P
Posted on Aug 03, 2009
  • 7 Answers
SOURCE: Samsung LN-5265F LCD TV is very slow to come on.
its the elecrolytic capaitors on the power supply.
it shows how to fix it yourself for only 'peanuts'
Posted on Aug 05, 2009
SOURCE: TV wants to turn on & off (clicking sound)for about 10 minutes.
I had the exact same problem on my LN-T5265F LCD (clicking on and off - stays on after 10 minutes). I just followed the advice here. - I opened up the TV (very easy 20 or so screws).
- Took the cover off the BN44-10150A power board.
- Found the two bad capacitors on the top right of the board. (They were bulged on the top)
- Went to Radio Shack and purchased two 1000uf capacitors
- De-soldered the old caps and soldered in the new ones
- Screwed the TV back together
- Powered it on and it is working great now!
Thanks to everyone who posted here. A repair that could have been a several hundred dollars with a service call, turned out to be a $6.00 fix by replacing a couple of capacitors myself. The wife thinks I’m a genius. Funny thing – I told the guy at the Radio Shack what I was doing and he said “why don’t you just get a new TV, They’re very inexpensive now”.
Posted on Sep 06, 2009
  • 59 Answers
SOURCE: 42 inch samsung lcd tv tv takes forever to come on
I would check the power supply for bad caps they will have a swollen top replace those and that should fix your problem
Posted on Jan 28, 2010
  • 8457 Answers
SOURCE: When I turn on my
This problems very common on a LCD tv.It the tv power supply board,have bad dying capactors,these capacitors are alway bulges or puffing up on it tops.That the board,where the power a/c cord plug into it.U have all the tools,know basic electronic and can do basic soldering?Just check the power supply board,for those dying capacitors that bulges or puffing up on it tops.Replaced these dying capacitors on the tv power supply board,ur tv will power up normal again and have no more clicking sounds and will not take anymore 2 mins or more to turn it on.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Posted on Nov 25, 2010
0 characters
1 Points
Can't get my samsung hp-t4254 42" plasma tv to
make shure that the computer is set up to display on the screen. To check and see right click on your desktop, click on the option that says screen resolution, and then change your settings from their. The tv will not register that you have a computer plugged into it if the computer is not sending the tv a signal.
Mar 05, 2011 | Samsung HP-T4254 42 in. Plasma Television
Samsung 42" Plasma HDTV cable hookup problem
There sould not have been sparks. Check the following: Using a voltmeter check between the cable itself and ground. There should not be any reading (anything less than .1V is normal). Check again between the inner hole of the RF connector and the outside part. Again there should be less than .1V. If you read any voltage at the RF connector, the TV is faulty and should be exchanged. If you read voltage at the cable, have teh cable company check again.
Jul 30, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Short circuit on the "Y" sustain board
The problem is heat!!! If the tv has fans they should be checked for normal operation,although on the early samsung models there were none, and the problem is that the panel drive buffers are getting to hot due to inadequate cooling. This is most apperent when tv is mounted to close to the wall, also external fan blowing on the rear left side will dissapate the heat. It is a problem on early Samsung and Electrograph 42 " plasma models. Hope this helps.
Jul 28, 2010 | Samsung Flat Panel Televisions
3 y/o Visio VU42L with no pix or sound
well,mike seems youve done everything to your TV and nothing happen..Try to reset the system of your TV.On the main board there is a small button just press it to reset your system and see if your TV will work again tnx.
i hope i help you..
please rate my help...
Jun 06, 2010 | Vizio VU42L 42 in. LCD TV
Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HP-P4271 42 in. HD-Ready Plasma Television Logo
18 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
