Question about Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive
Failure to operate hard disk
My cpu was long time been stored in the corner(almost 6mos.)and when I try to use again the cpu is not working.I have tried to consult a technician but failed to make it.Reason is that according to them it was already been damaged.When they tried to fix it,the monitor respond but was the hard disk drive wasnt respond.My only after is the program which i want to be recovered.
  • what is that Jan 01, 2008
    I really appreciated your time to answer my problem about my computer.God bless you!I know that God will reward your kindness in any ways.I will inform your column later about the results and ask more help when needed.More power!
    Brigadier General:
  • 6,966 Answers
If I understand your posting correctly, the computer need not be repaired since all your after are the files stored in the old hard disk (HD).
If that is the case, you simply need an external drive enclosure to house the old HD (chances are IDE) with USB cable interface to be hooked up to another PC that is operational. From there you can then copy/move your files. This is of course assuming that the HD is still working/operational/recognized by the 2nd PC. Additionally, you can also run file recovery software(s).
You can borrow such an enclosure from a tech friend or purchase your own from any reputable computer shoppe/store.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 31, 2007
  • Louie  Role
    Louie Role Jan 01, 2008
    Happy New Year!
My pc compaq nc6220 cannot boot,some time it show disk controller failure,some time no disk system or disk error and som time a blue screen appear on my screen.please help me.
Your hard drive may have crashed.This is so proven by the 'blue screen' technically referred to as 'the screen death'.
  • First,you may try removing the hard disk,leave it for a while and re-fix it again.Start the PC.What happens?
  • If still wont start, you may have to try and re-install the operating system again.
  • If the operating system wont install on the drive,replace it.
Hope this helps.Thanks!
Please rate this answer.
Oct 22, 2011 | HP Compaq nc6220 Notebook
What is the use of RAM?
The ram is basically the speed memory, any programs open are saved to the ram while in use, the more ram the more things can run. Hope this helps :)
Jun 06, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
About disk boot failure
Hi!
Disk boot failure means that your BIOS can't find the master boot record of your computer which resides in the hard disk or a floppy disk.
This indication means that your hard disk drive is not detected by your BIOS or their is no operating system installed with it.
Have a nice day!
Jun 02, 2010 | Foxconn WinFast K7S741MG Motherboard for...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Hard disk problem
Better to check if your Hard Disk have a power. By knowing that it is working you have to go BIOS and see it there that it is recognize as Primary or Secondary Setup. Boot Failure have the options why it won't run from the hard drive. #1 Maybe its not detected in your PC or no power, check again inside your CPU if it is properly connect. #2 No windows or any system available. #3 If all of this are not then your Hard Drive are defective.
That's is my analysis on your problem. Hope this might help you to know what is that problem for.
Aug 05, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Mother board or CpU Doesnt work. technician said I have a ghost inside my CPU!
verify your bios settings with regards to what the pc is expecting in way of hard drive.
Do you have the luxury of another hard drive that you can try on this pc ? - this will 'suggest' where the problem rests.
Make sure the lead is fully located on the back of hard drive.
If possible - change the lead for a 'known working' lead (Maybe from the computer that your hard drive was recognized in)
Aug 15, 2008 | Seagate (ST307504FPA1E3-RK) Motherboard
Hard Disk Failure
as the hard drive have movable parts it will fail one day.
If you defragement your hard drive monthly then it will take good care of your hard drive.
As the inspector is saying you should be ready for failure of your hard drive and you should back up your data.
Jun 19, 2008 | Microsoft Windows Vista Ultimate Edition
Problem wth xp2
check the connetion of the datacable and power supply to the motherboard and hard disk if it is ok then try with another datacable if the problem persists than you are having a bad hard disk replace it
May 16, 2008 | Microsoft Computers & Internet
Laptop HDD boot problem
I would be inclined to think this was the beginnings of a hard drive failure. Typically these failures are due to mechanical wear on the disks where data is physically recorded. You can continue to use it, however, be aware that when it finally does fail you will likely corrupt some if not all data stored on the drive. At your first opportunity you should back up all data, pictures music, Internet favorites to CD or USB drive. You should also ensure you have your restore CDs for your operating system and any other programs you?ve since installed as well.
Nov 15, 2006 | Dell Inspiron 3800 Celeron 500MHZ...
Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive Logo
53 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
