Question about Dryers
Zanussi Tumble Dryer
I have a zanussi tumble dryer TC7102 which is only 2 years old. The indicator light came on to say the water tank was full so i emptied the tank and now it will not switch back on at all.
  • Anonymous Mar 26, 2014
    too noisy when working,is it a baring, specially when changing direction of spin
  • 126 Answers
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Posted on Jan 25, 2008
Zanussi tumble dryer zdc37202w where does the hose fit as i want the water to go into siphon and not the condensate tank.
Unfortunately, nowhere in the user manual does not described how the connecting hose to drain water into the siphon.
Feb 18, 2015 | Zanussi Dryers
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Feb 28, 2009 | Zanussi TC7102W Electric Dryer
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
Mar 14, 2008 | Zanussi TC7102W Electric Dryer
Tumble dryer
This is the problem of your dryer's circut board. call the person from whom you have buy this and if dryer has gaurenttie period then replace if you want to get relief in future. ANKAJ
Nov 29, 2007 | Zanussi TC7102W Electric Dryer
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
953 people viewed this question
Top Dryers Experts
