Question about Canon PIXMA iP4300 InkJet Photo Printer
Paper jam error, no paper to be found
Hi, I can't find any paper anywhere...  must mention that I ignored a low ink sensor to finish printing a project.  The printer sent a few more pages through in the following days, but then reads paper jam, and won't print any more.  I'm not sure if those two things are related.  Any help appreciated! Thanks!
  • 417 Answers
Hi there I had one of these back at the workshop with the same problem it turned out to be a drawing pin that had stuck down the paper path. When you ope all the covers does the jam go away? If not there maybe a torn piece stuck in there. I don't think the two are related but worth a try to change ink. The other thing is that on some canon products you will have to press the stop button the clear.
Try this hope it works if not please get back to me.
Posted on Dec 30, 2007
6b10 error, meaning?
Hi this is what i found for your problem hope it helps thanks. Paper feed cam sensor error or Error Code 6B10
Condition: An error occurred in the paper feed cam sensor during paper feeding from the cassette, or the paper absorbing a large amount of ink jammed in the PF rear guide.
Problems and Solutions:
  • Jammed paper in the PF rear guide (when a large amount of ink was absorbed in the paper);
    - remove the jammed paper and foreign material.
  • check for foreign material or paper debris in the cassette or in the PF rear guide;
    - remove foreign material.
  • If other solution fail, replace one off the following part
    - PF pick-up unit
    - Logic board
Sep 21, 2011 | Canon PIXMA iP2000 InkJet Printer
My Officejet 6500 keeps saying "paper jam" even though I am sure there isn't any jam. A search of the internet let me to disconnect power cord for 30 seconds and press # 3 to reset the machine. ...
Hi I also had this issue. no paper anywhere but still the message. I found out that it was also not possible to move the carriage. I teared the device apart. found out that the ink cleaning mechanism was so filled with old and sticky ink. I cleaned it all,what a job..wear gloves I can now advise..and then it start working again...
Nov 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Error 6400 ink cartridges wont track accross
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Feb 07, 2010 | Office Equipment & Supplies
ERROR E 2 comes up on the little lcd screen when i try to print now.
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 26, 2009 | Canon PIXMA MP160 All-In-One Printer
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
97 people viewed this question
old marine
old marine
