Question about Fujitsu LIFEBOOK P1510D Tablet PC
Notbook is crashing
I own a Fujitsu 1510D.
Since recently, evrytime I move it it crashes, somtimes restarts, sometimes I am getting a blue screen.
I restored all the software from the restore disks, that did not help.
I realized that itmust be a hardware issue, thought that it is the memory, I replaced it, did not help.
Can it be the motherboard (or chipset on the motherboard)? If so, is it worthwile to repair? Please advise.
  • eilat Dec 30, 2007
    Thanks, but I already checked out those power related possibilities.
    To your question: Yes, if I let it rest on the table it works pefectly, if I tilt it or lift it it crashes.
    Somtimes, after crashing not even the BIOS comes up, although the display is on. When the BIOS does not comes up the three lights capslock, numlock and fnlock are not bliking upon stratups, although the notebook is powered (the power swith is lit).
    Thanks in advance for your help!
  • Anonymous Aug 21, 2008
    on a fujitsu lifebook S series.
    it starts ok, but whenever I move it slightly, tilt it, move the screen or any physical interaction which is more than a light keystroke,
    it does one of these things :
    black screen, no response
    blue error screen followed by black screen
    freezed screen, no response
  • 185 Answers
Hi.
This could be as simple as a loose or poor connection somewhere. There are a couple of things that I would look at. Firstly, try another ac mains adaptor incase the power lead is intermittent. Next you could look at the power socket on the back of the laptop. These can play up and sometimes are responsible for poor connections. The above will be made worse if you have removed the battery or if the battery is old or poor. Put a decent battery in and keep it charged even if you are using a power adaptor. If there are breaks in power the battery will act as a reservoir and prevent dropouts.
You say that it crashes when you move it, is it ok when you leave on a table and operate it?
The only other thing I can think of is that there could be a loose connection inside the unit. I would check out the connection ribbons before pulling out chipsets or motherboards. Good luck..
Posted on Dec 30, 2007
WHY MY TABLET FREEZE AND NOT MOVING
FIX Slow, Frozen, Android CRASHES! Cache/RAM TIPS ...
? 7:50
https://www.youtube.com/watch?v=bKt3UEBpD44
Aug 31, 2013 - Uploaded by p1nesap
And no, adding yet another app is NOT the answer! ... So if your Samsung Galaxy phone or Nexus tablet is ...
Android Tablet stuck on boot screen ! Bypass it in easy steps ...
? 4:36
https://www.youtube.com/watch?v=HErn0-GcQqE
Jan 4, 2014 - Uploaded by My Tablet Guru
1) Press the volume up or volume down or home button when thetablet start, this is hit and trial method and ...
Device keeps crashing, freezing, or restarting ' T-Mobile ...
Dec 29, 2015 | Tablets & eReaders
Ipad 2 has a transparent line moving across screen
have you tried a hard ware reset?
turn off device, then hold the power button on top and the home key (make sure its not plugged in also)
keep Holding both keys... you will see the apple logo appear, and then flash off, and then it will restart again. If you keep holding the home key and the power key, it will continue in this loop. Holding it until it reboots once should be enough though, then just turn it on and let it boot normally.
Your settings and everything should remain the same, this just will reset the hardware on the device. I have had issues with my iPad 2 with games lately, mainly random crashing, when I do this hardware reset, it usually fixes my crashing issue for a while.
Once again the steps are:
Shut off device, make sure it is unplugged
Hold the Power button and home key, until the apple icon appears and then flashes off.
Let the device turn on normally, let go of home key and hold the power button till the apple icon appears, and let it boot up normally.
Test the application, this may or may not work. But its def worth a try.
Mar 07, 2014 | Apple iPad Tablets & eReaders
How do I stop apps from crashing on android tablet?
you cannot stop an app from crashing on any tablet or computer because programs have bugs and depending on the operating system you are using as well. For example, if the app is compatible with Android 5.0 and you are installing it on a tablet with Android 6.0 it might install but might not work properly. The only way to fix the crash is to send the crash report to the developer to fix the bug. Sometimes you can fix it on your end by using various tool out there like Master Cleaner to clean up your tablet but this will only help to some degree but does not guaranteed that the app will not crash
Jan 17, 2018 | Tablets & eReaders
My iPad's browser is constantly crashing
Close unused tabs
Tap Settings in your Home screen then tap Safari / Clear History, Cookies, and Cache.
Then restart your iPad. Press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
Dec 15, 2011 | Apple iPad 32 GB 3G Tablet PC
How do you get your screen to show again if it's black?
it shows bubbles in the middle tablet and with blue and green line
Mar 11, 2011 | Tablets & eReaders
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Feb 28, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
Have an hp tc1100 I don't know a lot about computers. I can not get it to stop on the blue screen of death to see what may be the problem. I have tried to photograph so I can read,the most I can get is...
Installing a new BIOS when your laptop is in such an unstable condition, is very dangerous as it may crash during upload and write off the mother board.
Try starting in safe mode and run CHKDSK/F from the start/search box. That will clear any errors on the hard drive. The most blue screen failures are from hard drive errors and memory errors.
Hope that helps.
Feb 02, 2011 | Compaq tc1100 Tablet PC
Blue screen. Works ok in safe mode, crashes in normal boot
Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you.
Mar 07, 2010 | Fujitsu LIFEBOOK P1510D Tablet PC
Numbers typed with letters
What Operating system have you got?
Try resetting your regional settings in Control Panel.
Have you dropped it accidently?
Aug 15, 2008 | Fujitsu LIFEBOOK P1510D Tablet PC
Laptop breakdown
welcome to fixya
i would reinstall windows
you could have a viruse that is stoping you from loggin in to your main screen ...reinstalling windows might wipe out what ever happen to the computer
have a great day :)
Aug 07, 2008 | Fujitsu LifeBook T4210 Tablet PC
Fujitsu LIFEBOOK P1510D Tablet PC Logo
157 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Tony
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
