When you power up the computer press F8 key then enter in enable vga mode then go to start ->control panel ->display ->settings . Change screen resolution to 1024*768. Then apply and ok. But if you are not able to see any display so you need to refix RAM memory if you are able to enter in safe mode or enable vga mode then there is only issue with graphic driver. Let me know if you need more assistance. Thanks.
Comments:
Oct 23, 2009
- for that open back cover orf laptop and refix RAM memory. Pull cmos cell from motherbord for 10 minutes.so all settings goes to factory defaults.
Please rate my solution if you really want to tell me Thanks.
Was this helpful?
Yes
No
Popular Solutions for Fujitsu Siemens SCENIC P300 PC
cd rom not working error code 19 acording to device manager .this is on acer aspie x3200. it will...
(More)
cd rom not working error code 19 acording to device manager .this is on acer aspie x3200. it will not run a dvd or cd on windows media player . have set all defaults to windows media player
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. ...
(More)
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. I've tried using a repair program but it says the C: partition1 is unknown and cant use this area.
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm...
(More)
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm pretty sure it freezes. What should I do?
