Question about Minolta Di3510f Bizhub Copier
Toshiba estudio 350 error no f105 - Minolta Di3510f Bizhub Copier
    Problem Solver:
  • 9 Answers
Try reformatting harddrive and if that doesn't work, Replace the drive.
Posted on Dec 31, 2007
How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350How to ikj adjust estudio 350
If wait warming is occur on the panel, and it wouldn't change to ready, then fuser unit is the cause. Need to check the themistor and themostat on fuser unit.
Feb 15, 2014 | Toshiba e-Studio 350 Copier
F105 reboot call for service
[F105] HDD other error
Check if the connectors of the HDD are disconnected.
Check if the connector pins are disconnected or the wires of harnesses are broken.
Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
Feb 23, 2012 | Toshiba estudio 255 Copier
Toshiba estudio 350 error detected c 260 what can i do for fix this error ?
Scanning system service call
check if the scanner connected well or if any material ****** the scanner
Jul 04, 2011 | Toshiba e-Studio 350 Copier
Toshiba estudio 350 error detected c 260 what can i dofor fix this error ?
Scanning system related service call
check if the scanner connected well or if any material can stop scanner moving
I need software toshiba 350 copier
I hope this link helps!
This the is the windows drivers/software for the Toshiba eSTUDIO 350 Copier.
http://www.top4office.com/drivers/toshiba-estudio-350-photocopier/
May 04, 2011 | Computers & Internet
I have e studio 600, and it is not working, has error code F105. Plese help me.
Hi, that is a hard drive error and the control panel. The copier use the hard drive so you cannot take it out of the loop. You can try to reformat it but if that fails then you will need to replace it. I ALWAYS replace a hard drive that has coded out ... but if reformatting it works then you don't always have to.
Take care
Jul 18, 2010 | Toshiba Estudio 200L Copier
Error code F105 studio 450
F105 indicates HDD other error
Sep 17, 2009 | Toshiba e-Studio 350 Copier
Reset fax data in toshiba estudio 350/450
how do I find my IP address for my Toshiba e-studio350
Nov 30, 2008 | Toshiba e-Studio 350 Copier
Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
Dec 30, 2007 | Toshiba e-Studio 350 Copier
Open Questions:
ricoh aficio sp C232SF / c231sf When enabled, initializes but does not print Ricoh Aficio SP C232SF / c231sf The situation is. When enabled is initialized, writes that greeedy and is in readiness. No mechanism at this time does not work, except the scanner line. Scanning Starts, black and white is faster than the ruler, the color is slow. The document feeder works off a sheet and hands. After all the manipulations on the display Processig shines indefinitely no mechanism works until you press stop. The same situation when you try to print reports or when sending to print from a computer. the driver stood on the USB bus. Using command center see it all, but printing is also not achieved. Sees the tray and the presence of paper. Now this is the strange print though, and no, the black toner decreases. Already there was an inscription about it on the display and in commands the center shows the decrease in black. Only black. If you press for example copying, will stand and-writes about the heating of the stove no mechanical work and after a couple of seconds is ready. Stove at this time safely lying on the table next to the machine. the line Lamp is normal, but no power is supplied to it. The power supply did not find any problems. In the service you start the registration-work out the engines of development and tape, and a couple of auxiliary. Tried to make init EEPROMy, tried to rewrite the data in it, as if installing a new one-no changes Any ideas and assumptions are accepted And for dessert - a main Board, engine and the controller changed. The situation is quite similar. Sew and successfully both through the grid and through the USB port. I don't know where to look
Sep 23, 2018 | Ricoh Office Equipment & Supplies
See all Minolta Di3510f Bizhub Copier Questions
195 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
