Question about Zanussi FJS1225W Front Load Washer
Sounds like a plane landing
All of a sudden when the machine spins it sounds like a plane about to land in the kithen.
Not sure where to start looking, any ideas?
The machine is still washing clothes fine, just very noisy. Its nearly 3.5 years old.
Thanks in advance
  • Anonymous Jan 05, 2008
    there is something in the inner drum scrapping against the outer drum and i dont know how to retreive the item?????
Sounds like the ball bearings usually located in the rear wall between the inner tub and the belt drive pulley are bad most likely from corrosion leading to wear of the bearing.
This usually occurs if water seals fail and soapy water finds it's way into the bearing.
I suggest you get the experts to handle this rather tough job.
Baba Anji
Posted on Dec 30, 2007
Where do you land if there is an emergency during a trans-atlantic flight?
You're stuck with a water landing (ditching). Hopefully at altitude the pilot can see a ship and make the landing in the vicinity of the ship for quick rescue. It so rare for a plane to lose power to all engines though that you should never hear of such an incident. Depending on the route, however, Bermuda may be within gliding distance.
Jan 04, 2017 | Aircrafts
What are the chances of surviving a plane crash at like 30 000ft?
This depends on whether the plane breaks up in flight or just loses power and glides to a landing. Usually a plane can glide and land just fine without the engines if there's a suitable place to set it down.
Washer machine shakes when it spins and sounds like a helicopter landing- is not out of balance- and is leveled
sounds very like the bearing are gone i am afraid not good news its quite expensive to replace them if your machine is splitable
Oct 14, 2014 | Kenmore HE2 Washing Machines
Is the video of plane landing on Nissan truck real
No, it's just an advertisement for the said truck.
Jul 13, 2014 | Computers & Internet
I can not get ILS landing to work on any planes it did work a few times before I installed the 2 service packs they fixed the sound on some planes but not the ILS landing
Are you running the Flight Simulator X, or the gold edition? The key difference here is that the Gold Edition has the Acceleration Expansion pack, and therefore recommends that you do not install the SP1-SP2, as the software outdates both the service packs. If so, uninstall the service packs and that should fix your problem!
Jul 29, 2010 | Microsoft Flight Simulator X
Spin cycle
Sounds like the counter balance is off on the washer. If you tilt the washer back underneath by the motor should be a large brick like block. Make sure it is fastened to the frame tight and if it is check to see if all the level adjustments on the legs are adjusted properlly to keep it from moving ,banging around when its spins in the spin cycle.
Many times there are tentions springs under the washer too to adjust the weight make sure one has not come loose.
Hope this helps
May 19, 2009 | Washing Machines
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Washer making crazy sounds
I have had this problem asked a lot and the answer always seems to end up the same. the legs are not perfectly level or the washing machine is on a wood floor. These units have no forgiveness for a floor that has any flex at all. A way to confirm your problem is you can take it out to the garage adjust the legs and run the unit. It almost always runs fine on concrete. Sorry there is not an easy fix for this. Please rate this answer if it helps, thanks, David
Dec 06, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Loud Noise - Spin Cycle
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
70 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
