Question about Denpa USB-24 Digital Voice Recorder
Harbinger Voice Recorder
I have an Harbinger Voice Recorder, coming back to transfer files to my pc, I noticed that I have lost its software. It seems that files with HGL extension is not anywhere to be found.
0 characters
1 Points
How can I transfer files form a VN-2100PC recorder
Digital Wave Player (2.0):
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update:
Download update 2.1.3:
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Mar 03, 2009 | Olympus VN-2100PC Digital Voice Recorder
Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
Jan 21, 2009 | Olympus DS-30 Digital Voice Recorder
Olympus digital recorder WS 110, keeps saying connect to pc
the only thing left to try is to try and format the device and see if you can restore it back to factory default settings. You go to the menu and to the format option. This will permanently remove any recordings you have done and as I said restore the device back to factory settings. If that doesn't work then you will probably need to send it to Olympus for repair service.
Dec 04, 2008 | Olympus VN-3100PC Digital Voice Recorder
Digital Voice Recorder VN-3100PC transer from PC back to recorder
With this particular model of recorder that functionality is not possible as when the recorder is connected to the computer it is not a USB Mass Storage Device. It will only files to be downloaded to the computer not uploaded back.
Dec 02, 2008 | Olympus VN-3100PC Digital Voice Recorder
Can't seem to transfer files to computer
The memory is probably corrupt. Use the reformat feature from the menu. Any recordings will be lost.
Oct 31, 2008 | Olympus VN-3100PC Digital Voice Recorder
Cannot play .HGL files once files have been downloaded to my computer
Unless you have specific software to play the .hgl files (you could do an internet search for "hgl player"+"audio" to try and find a standalone .hgl player if you want to try this route) then you'll need the program Converter 1.4 that comes on the CD shipped with the product. This software is a program that decodes the compressed recording file (the .hgl) and converts it into a .wav file that can be played using most any PC media player; from there, you can listen to it or recode it as an .mp3 or whatever you want to do with it.
Hope that helps.
Aug 25, 2007 | Denpa mp-36 128MB Handheld Digital Voice...
Harbinger Decoder
Okay, I'll try and help you out...
1. Create new folder on desktop called 'recordings' or something similar i.e. easy to remember!
2. Connect unit to PC via USB cable and turn on the unit. If you slide the HOLD switch to the on position, you should get a message saying "PC LINK" on the display.
3. Locate the recording(s) that you want to decode. I don't know what model of denpa you have, so I can't be sure, but there are normally four folders (A, B, C, and D - there may also be an MP3 folder). The recordings are accessed by double-clicking my computer, then the removable disk icon that appeared when you plugged in and turned on, and then opening the folders that are present which contain the recording(s) you wish to decode.
4. Identify the recording(s) you wish to decode and copy them to your newly created desktop folder (right click the file/copy and then go into new folder and paste there).
5. Once you have copied the file(s) you want to decode, open the Converter program (programs - harbinger converter - converter 1.4).
6. In the program window click on the magnifying glass in the top box (source file) and browse to your new folder.
7. Select the file you wish to decode (I think you have to do them one at a time - just repeat the process for each one following these steps).
8. In the lower box (output file) enter the name you wish to use to identify the file so you can find it. Then click on the magnifying glass for the output file and browse to your newly created folder (this will then be where your converted files will be sent on decoding).
9. Click the 'decode' button in the lower left corner of the program window (I think it shows a picture of two different sized cogs side by side).
10. The file should then be decoded from its .hgl format to a (new) .wav format with whatever name you gave it. From here, you should be able to listen to the file on your PC using any common media player (i.e. Winamp/Media Player etc.) or recode it as an .mp3 if you want to save some hard disk space on your computer.
Repeat the process from step 6 for each file you want to decode.
Hope that helps and good luck.
Jun 21, 2007 | Denpa USB-24 Digital Voice Recorder
Denpa USB-24 Digital Voice Recorder Logo
183 people viewed this question
Top Denpa Voice Recorders Experts
David Burkhart
David Burkhart
Are you a Denpa Voice Recorder Expert? Answer questions, earn points and help others
