Computers & Internet Logo
Posted on Oct 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When logging on error message telling me disk nearly full delete files etc
Anonymous
Level 2:
  • Expert 134 Answers
  • Posted on Oct 22, 2009
Anonymous
Expert
Level 2:
Answers
134
Questions
0
Helped
48330
Points
381
You must clear your drive C: of some big files, if you have a partition, it is good to transfer your files there, it slows down the computer if your disk is full and might not logon because it can't load your profile if it's full.
Anonymous
Level 3:
  • Computers & ... Master 32,281 Answers
Anonymous
Level 3:
Answers
32281
Questions
Helped
7913244
Points
102259
This message means the hard disk is nearly out of disk space.
Do you regularly do a Disk Cleanup and empty the Recycle Bin? These disk maintenance chores will free up disk-space by removing old temporary and compressed files. Therefore returning disk space for further use.
To do a Disk Cleanup follow these steps. This can take hours to complete, it depends upon the size of the hard disk especially if it has not been done before.
Click on My Computer - right click on the C drive and click on the Disk Cleanup button. After it analyzes the hard disk then click all the boxes to recover the maximum disk space, click OK then YES to perform these actions.
How To Fix MS Word Disk Full Error?
The message of disk full means that your disk is full. You need to delete unnecessary programs and files in order to create some room.
I'm getting an error message of 0xb900009f
Lots of issues can be responsible for your error message:-
Access deniedThis error occurs if the user has insufficient privileges to a file, or if it has been locked by some program or user.The device is not readyThis error most often occurs when there is no floppy disk (or a bad disk) in the disk drive and the system tries to perform tasks involving this disk.File not foundThe file concerned may have been damaged, moved, deleted, or a bug may have caused the error. Alternatively, the file simply might not exist, or the user has mistyped its name.Low Disk SpaceThis error occurs when the hard drive is (nearly) full. To fix this, the user should close some programs (to free swap file usage) and delete some files (normally temporary files, or other files after they have been backed up), or get a bigger hard drive.Out of memoryThis error occurs when the system has run out of memory or tries to load a file too large to store in RAM. The fix is to close some programs, or install more memory.[program name] has encountered a problem and needs to close.
Couple of things my mac start up disk there is a message saying it is close to be full i deleted over 900 files and it is still giving me that message second is when i try to edit a track in garage band...
The only reason you would still be using disk space is if you haven't Emptied the trash can (assuming you deleted files that are large enough to count.) On the Dock you can Click on the Trash, in the right upper side of the window is an Empty button. Press that and you should end up with an empty window. If you get an error about deleting certain files, try holding down the Option key on the keyboard when you click Empty. If this doesn't help download "Disk Inventory X" (a free utility, google it) to see where your file space is going. Sometimes you delete a bunch of stuff, but a log for or something else has gone crazy and is still taking up all the space. Disk Inventory X will help you see that kind of thing. Hope that helps.
2answers
I cant delete some video clips from my pc, every time i tried to delete it, a message appeared.. saying " Make sure the disk is not full or write-protected and the file is not currenty in use" ...
Seems like files and/or folder is write protected ( in Read Only Format ).
Right click on the folder and click on properties. Check if there is a check mark on Read Only or any such other check mark. If so, remove those check marks and then open the folder and try to delete.
If this does not work, Check with the file you wanna delete in same way.
If it still does not work, you most likely do not have permission to delete files on your PC profile that you login with. You either need to be administrator of the PC with admin rights or the person who has the admin profile should give you full rights on your profile.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
1helpful
I have a Dell Dimension 4600 PC. I get error messages saying "cannot find install log" Does this mean a full restore??
Yuo missed a log file by some reason . somebody has delete a log file . check your recycle bin if you see a filecalled" install "restore it . otherwise you have to copy back that file .
this wrning is not asking you to full restore
12helpful
2answers
Where is Samsung Hard Disk service center in kolkata?
Here's a long list of samsung service centers in kolkata. When you click each one, you'll get the details.
HTH,
Regards,
Deboo
Error: phone memory is full, even if all files are deleted
format your phone - but you will loose everything
Otherwise go to memory details - go to applications and select options, scroll down to memory details and select phone memory. check how much u have used and what is free. Then delete accordingly - all your music files etc etc and bingo - now stop the tears
4helpful
The size of squid log files of my proxy server are geting too big for my disk space. I manually deleate them when the disk space is gettin full & the squid service is stoped autometically.How can I delete...
Find your squid.conf file. Likely path to it could be /usr/lib/squidc/etc, or
maybe /etc/squid.
That file should contain a setting for logfile_rotate, probably at a default of
10. Change that to 2.
Then add a once-a-day job to root's crontab, on the order of:
1 1 * * * /usr/lib/squid/bin/squid -k rotate
Grand Canyon Tech
Grand Canyon Tech
