Question about Bosch 24 in. SHU53 Built-in Dishwasher
No water coming in
SHU4322 UC U12
At first, the drain failed, so I shop=vacced the water out and now it drains fine.
But now no water will enter the chamber (it will not prime) to wash the dishes.
  • 1 more comment
  • Anonymous Jan 12, 2008
    Bosch dishwasher won't bring in water to wash dishes, just buzzes
  • Anonymous May 12, 2008
    Dishwasher turnson econo cycle (74 min.) but no water comes in. Motor still runs. It does pump out the water in drain.poured some in to see what would happen.This problem started after the sink drain clogged. Bottom of dishwasher filled with water. When I opened the door water ran out the bottom of the door. Shoud I turn it on and let it run the full cycle with out any water in the tub ? Thanks
  • garciafamily Jun 24, 2008
    Our kitchen sink clogged while we were running a regular dishwashing cycle.  We noticed water leaking from the door seal, stopped the dishwasher and attended to the clog.  Now, the dishwasher pump runs....the timer says anything from 7 min to 78 minutes, and the washer will not fill and cycle....it's stuck on pump!  Any ideas?
    President:
  • 1,314 Answers
Check water line for kinks make sure water is turned on check water valve
Posted on Dec 30, 2007
  • robert samples Dec 31, 2007
    there is a safety in the tub that keeps the tub from overfilling if it gets hung up or is not touching the float leaver which most of the time you can remove the bottom panel and see the micro switch it will not fill or if the switch is bad it will not fill i hate to stop when its not fixed
As it fills it drains and never fills up and starts. Not all the time though sometimes works fine. What part is failing? Thanks
Water is siphoning because the end of the drain hose is lower than the water level, or, there is no air gap where drain hose enters wall drain (house plumbing). The wall drain needs to be at least as high as the top of the washer.
Feb 22, 2011 | Washing Machines
Have a UC code. Washer starts than stops during cycles when the drum is moving. also hear a clicking sound Tx, Bob
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Neptune TL washer and I am experiencing
Hello bucknerkim,
Take a look at this post Clutch repair post and see if you can DIY… I will help you. Thank you for posting your model type.
The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference.
Try the TDS check first’ from the Service Manual slightly modified;
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM. This done thru the lid.
a. Enter Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine.
You can pump out the excess Tub water with this process from the Service Manual;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Turn off the drain pump with twith the off button or hit the Presoak key.
Post back if you have questions or concerns….Rich
Nov 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer keeps getting dc code, doesn't matter how big the load is. Have unplugged the machine and moved clothes around but it still keeps doing it.
Most of the time this is a clutch malfunction. If you feel you can DIY after reading this post we will try to help.
I always recommend folks to check the Tub Displacement Sensor its fairly easy to do thru the washer lid.
Some handy links the Service Manual for reference. Sears Parts Direct for reference.
TDS check from the SM slightly modified;
e. Press Hand Wash.
Poat back if you have questions or concerns....Rich aka dh1200s
Nov 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800AW 27'' TL WASHER WON'T DRAIN WHAT SHOULD I CHECK FIRST?
Hello chandler_wes,
Here is the Service Manual for reference. Sears Parts Direct for reference.
Are you falling in spin cycle with any error codes to the LED console display such as dc and or UC which are unbalance error codes usually related to a clutch malfunction? The error codes could also be caused by Tub Displacement Sensor failure/issue. Do you take a fail code of ND which is no drain? Try this TDS check thru the lid as a first step…. Good practice to get into to Service Mode. I'm suspect of a clutch malfunction but need more info related to error codes.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
e. Press Hand Wash.
From the SM;
If the issue points to a Clutch malfunction see this post for clutch maintenance/replacement process.
Post back with an update to the error code question and if you want to put on your DIY hat.
Good Luck Rich aka dh1200s
Nov 09, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Bosch WFK2401 Drain Pump
I have a WFL 2060 UC on the bottom right there is a small access door. Inside the door you will find a drain plug which will unscrew counter clock wise. Water will come out so I tipped up the machine and slid a 1" deep cooking pan under the corner. When I unscrewed the plug I found a penny inside.
Aug 24, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
The water does not drain out.it's clogged
I checked the control panel, it turned out to work correctly, the drain pump has got the juice. Then I opened up the coverabove the drain pump (1 screw, below the drain filter) and God forbids, I found a chicken bone blocking the impeller of the pump. How it could get beyond two filter levels? Somebody must have opened the filter without looking if there was anything on the top of it!
So when the drain doesn't work next time, look for the most obvious: some garbage beyond the filters.
This was a BOSCH SHU5305UC/U12 type DW and until now it is fine.
When I checked the panel, I found that the power connector (the only triple one on the left side) had some burn trace on the black wire connector. It must be an erosion due to high amperage for the heating. I'll have to get soon replacement because erosion will continue until the whole DW will stop.
Jul 08, 2008 | Dishwashers
Bosch dishwaher shu 4322 uc/u12
remove outer door skin and kick plate at base pump will be on view turn off power look carefully at pump you will see a lever you have to cut away a small section of plastic on lever to be able to push it inwards pump then twists off anticlockwise is a bayonet fitting like a light bulb.
hope this helps
Jan 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher problem
there is a float in the tub looks like a little dome or such if its not touching the micro switch under it and pressing down on the leaver then the washer thinks its over filling and will not let the valve turn on remove the lower panel to see if its on the switch if not make sure the water is on then start the washer and see if the valve solenoid is getting power
Dec 30, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
170 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
