Question about MSI 645 Ultra333 Motherboard
MOTHERBOARD WIRING I HAVE 8 WIRES THAT CONNECT SOMEWHERE ON THE MOTHERBOARD. THEY ARE AS FOLLOWS, 1 +5V RED WIRE 1 -D YELLOW WIRE 1 +D GREEN WIRE 1 GROUND BLACK WIRE 2 +5V RED WIRE 2 -D WHITE WIRE 2 +D BLUE WIRE 2 GROUND BLACK WIRE WHERE DO THESE WIRES HOOK UP ON THE MOTHERBOARD
    Sergeant:
    Champion:
  • 243 Answers
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
Posted on Dec 30, 2007
  • Graeme Fallows Jan 07, 2008
    Please rate my answer if it helped ? Cheers!
How to install a thermostat?
Disconnect power. 1st run 18/5 wire. TStat wires are as follows : RED=24v GREEN=FAN WHITE=HEAT YELLOW=COOL BROWN OR BLUE=COMMON: UNIT WIRES REFER TO WIRING DIAGR
Oct 16, 2014 | Heating & Cooling
I have a 83 Honda Goldwing with a Clarion cassete player model # PH-890V There are seven wires that connect to the bikes wiring harness as follows blue, yellow,and green about 18 ga. Then there is a red...
the red is your constant voltage, the the yellow is your accessory voltage(used when you turn key this holds the memory in the deck. the black is the ground the blue and green are the speaker. the white is the ground for speakers as is the small black wire.. please rat this...thanks
Sep 02, 2008 | Audio Players & Recorders
WIRING A SINGLE PRESET DUAL DIMMER AND FAN SWITCH
Hi *****,
I'm an electrician and can help you with this problem. First - shut off the power. Check your wiring as I describe the connections below.
If this is the only switch operating the fan and light, it should be wired as a single pole in the direction sheet. That is as follows:
1) one black wire - it should be connected to the "hot" power source, 2) one green wire - it should be connected to the bare / green ground wires & switchbox (if metal), 3) one red wire - it should be connected to the fan hot wire, 4) one yellow wire - it should be connected to the light hot wire, the remaining wires (yellow with a "3 way label" and red with a "3 way label") should not be connected to anything and capped with a wirenut.
The wiring changes if you are using a second switch to operate either the fan or light (download & view the wiring diagram provided here to follow along with my text). In this case, the hot wire from the fan or light would connect to the black screw of a standard 3 way switch, and the remaining two terminal screws on the switch would connect to the red / red with 3 way label - or yellow / yellow with 3 way label pair. Power and ground wiring on the dimmer black and green are the same as the single pole wiring described above.
I hope this helps & good luck!
Jul 08, 2012 | Electrical Supplies
Have issues with trailer lights. Both turn signals on trailer flash when I use left or right turn signal. Have 7 pin factory plug. Lights on trailer work fine, hooked up to 97 Silverado. Act funny on 2000...
Standard wiring colors are as follows:
4-Way
5-Way
6-Way
7-Way
Green
Yellow
Brown
White
Red
Blue
Purple
Right Turn & Brake
Left Turn & Brake
Tail Lights
Ground
Backup Lights
Electric Brakes
Auxiliary Power
Green- Right Turn and Brake
Yellow- Left Turn and Brake
Brown- Tail Lights
White- Ground
Red- Reverse (Back Up) Lights
Blue- Electric Brakes
Purple- Auxiliary Power
It sounds like your green and yello wires are shorted together somewhere along the length of the harness. I would check the wires on the trailer first. Easier yet, if you have another trailer to connec or access to another to use for testing, connect to it and see if the problem repeats; if it does the trouble is in the vehicle's wiring.
Jun 26, 2011 | 2001 GMC Jimmy
I am wiring a honeywell thermostat model number ct87n if I select fan on the fan runs when out on auto /heat nothing but if I put on auto / cool and adjust the dial to a low setting the hea comes on....
there is it all depends on how many strands of wire are in there, they start at 2 wire and go to i think 8 wire and maybe more.
The wires are as follows:
1. red = power to stat.
2. green = fan control
3. blue or yellow = ac
4. white = heat
w1 = 1st. stage heat
w2 = 2nd. stage heat.
i am on line if you have any questions. wally
Feb 22, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
T101
Here's the wiring diagram:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
The wiring is as follows:
Connect _both_ the incoming and outgoing neutrals (white) wires to the "A" terminal. The incoming [(LINE) (hot) (from the breaker or source)] black wire is connected to the #1 terminal and the outgoing (LOAD) black wire is connected to the #2 terminal.
Both of the bare or green wires are twisted together along with a 6 inch or so pigtail using a red or yellow wire nut. The pigtail is then connected to the green "GR" screw on the enclosure.
May 07, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Heath-zenith sl-6107 wiring diagram
hi there the wirings colour codes for nz are as follows
OLD WIRING CODE
Green = Earth
Black = Neutral
Red = Phase Or Live
NEW WIRING CODE
Green/Yellow = Earth
Blue = Neutral
Brown = Phase or Live
============DANGER 230VOLT ===============
Electricity can kill.
You should use an Electrical contractor for this repair job,
Caution always turn off power first before touching any wiring,
The Live wires always carry power,from one point to another,
the black neutral is your return path from the live phase wire
the green wire is always the ground ,
In this example
the sensor will have four wires as follows
Green = Earth Wire
Black = Neutral
Brown = Phase (incoming supply) 24 hrs
Red = Phase Load (outgoing supply) from sensor to lights triggered
Notice there are to phases in the circuit.Brown and Red
Always treat them as LIVE or Active Power.
Brown will normally be the Live incoming power and
Red will be the load side of the sensor,
Check the brochure supplied by manufactuers or their website to confirm the wiring order is correct before commencing any installs or repairs,
Always Safety first.
Safe a live today and you'll remembered forever.
Jul 06, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Which cables go where???????
RED - YELLOW - GREEN - BLACK -----
1 3 5 7 9
2 4 6 8 10
May 08, 2008 | MSI PM8M-V Motherboard
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
MSI 645 Ultra333 Motherboard Logo
553 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
