Hitachi 55PMA550 55 in. HD-Ready Plasma Television Logo
Posted on Oct 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pink screen image not hd at all and most of the screen is pinkish at most times
Chi Chu
Level 3:
  • Hitachi Master 8,457 Answers
  • Posted on Oct 22, 2009
Chi Chu
Hitachi Master
Level 3:
Answers
8457
Questions
0
Helped
2822674
Points
26282
U use a HDMI cable connection in ur tv correct?Replace that cable still have same prob.Then ur main video backlight board is dying,must be replace.
Lumix DMC-FX07 shows purple/pink blurry image
It may be fixable, but would be expensive. Probably time for a replacement - they do not seem to be very expensive second hand.
1helpful
Samsung LCD TV 46 inch model LN46A550 has bright pink glow where it should be light (sky, lamp, etc)
My guess would be that you have a CCFL lamp that is failing. They will give off a pinkish tint when they are about to fail. But I would encourage you to get a professional diagnoses.
Image has lines and pink in colour
This maybe two problems, the pink color hue in the picture and lines from lens shutter problems. Your LCD is still good. You have to replace motherboard and lens.
Why are all of the pictures pink
CCD Imager chip is defective and giving tou pinkish image, replace ccd imager chip in camera to fix it.
Local camera repair shop will help you because it needs soldering work to replace that chip.
IXD 420U projector takes a long time to project and has pink ima
If possible, try to replace the VGA cable between the projector and the computer. A bent or broken pin, or a damaged wire, can prevent the blue or green (or both) portions of the picture from being displayed. The result is a reddish/pinkish picture.
As for the long time to project an image, this could be an extended warm-up time. How old is the bulb in the projector? Does the projector have an option to display the hours used and/or remaining on the bulb? Bulbs do have a finite life, and when they near the end of their service life, they can become more difficult to start.
Hope this helps!
A reddish cloudy swirl sweeps across part of my screen.
IF you are seeing a red or pink large oval area in the middle of the screen, I can tell you what the problem is.
It is not the lamp.
Let me know if you need more information--please confirm you have the red or pink oval.
SD TECH
Non-hd channels only. color is washed out with
try component cables and see if you get the same results.
3helpful
Pink screen and blurry pictures
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
