Question about Sony (B99860307) for VAIO PCG-K series Motherboard
Startup Mostly when I start the computer, lights come on but nothing more - once in a while, though, hard disk starts up and then laptop functions like noirmal. Any ideas/suggetsions?
  • 57 Answers
you should have specified about your laptop. but you can try the following steps.
1. check the powercord and battery.
2. check screen brightness and contrast.
3. assuming that you login . click start-> run ..( msconfig ) -> and press ok-> in the window that appears click the startup tab. now click disable all. this will probably help..
4. or you might be running Vista in a 512 ram.
5. or you can try to insert the windows installation disk and start the laptop. and if the blue screen appears continue reinstalling the OS. this would probably help.
Posted on Dec 30, 2007
I have a question mark sign on my screen please help
sounds like your hard drive has come unplugged, you will have to remove the battery and possibly the "L" shaped metal strip then you can push the hard drive back in
Feb 14, 2015 | Apple MacBook Pro Laptop Computer with...
Flashing folder when i turn on mac
Your hard drive may have crashed or it's settings have changed so it is no longer recognized as a startup (boot) drive. Try starting from your original operating system CD. (or borrow one). Press the C button at power up to force your computer to start from the CD.
Once started, don't install the operating system. Go to the pull down menu's and select Disk Utility. If Disk Utility sees your hard drive, select it and run the repair disk program. If it doesn't see it, your hard drive has likely crashed. You will have to replace it, install a new copy of the operating system, and likely have lost all your data and documents. This is where I would start.
Mar 08, 2014 | Apple MacBook Pro Laptop Computer with...
Function key switches external monitor
Hi
hope you have fixed the problem by now. However - the question mark ppears when teh machine cannot find a startup disk. It looks like a problem with your harddisk . Start uo from the CD that came with the machine and use the "disc tool" to try and repair your hard drive. maybe you can find some instructions here
Aug 02, 2013 | Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Laptop will not startup black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 15, 2011 | Acer Aspire One Netbook
Sometime it hangs on the startup when i'm already in the desktop
Please, if you don't have any programs like photoshop or financial program, run system restore.
Then, run anti virus program like kaspersky.
However, make sure you don't hear any noise from your Hard drive or laptop is cool for its best performance.
May 26, 2011 | Toshiba Satellite L645DS4030 Laptop
Can not start lap top
  1. If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
  2. Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  3. Step 3 If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
  4. Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  5. Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  6. Step 6 If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
  7. Step 7 If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it. (See also How to Fix Bad Sectors on a Hard Disk and How to Recover Lost Files.)
email me at clb199@yahoo.com for further instruction.
A 4 star rating for this help would be nice.
Nov 27, 2009 | Compaq Presario CQ60-220US PC Laptop
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touch buttons dont work properly.
Your Laptop is "booting up", which is another way to say that it's starting up. When it is doing this, it has a regular starting procedure and it is loading the Operating System and then the Programs you have installed on your Laptop. After installing a large program, or some software that requires a quick update/scan of your laptop - like antivirus software, it can take a few minutes to finish starting up your laptop. When it has finished loading all of the software from its startup menu and updating certain software, then any buttons (like volume or CD eject buttons that you may have pressed while it was busy starting/booting up).... these actions will then begin to be recognized by the laptop. So, while your laptop was starting up, if you were trying to turn up the volume on a CD that was in your laptop, nothing happened, and then decided to try to pop the CD out, and nothing happened, when the laptop was finally ready to acknowledge the buttons that were pushed, they seemed to happen automatically.
Bottom Line: Give your laptop enough time to startup completely on its own. While your laptop is busy during startup, there will be a little light on your mouse pad area that looks like a round storage barrel facing upward. After all your normal startup software has finished booting up and antivirus software has finished their tasks, you should be good to go. For me, my laptop has a 60-GB hard drive and I use Yahoo-IM (that starts up when my laptop starts up), and I have McAfee antivirus (which searches for updates when my laptop starts up, my wireless connection software looks for available wireless routers to connect to (not just mine), Windows Vista searches and installs updates, Google + MySpace + Twitter search for their updates, etc..... the barrel icon mentioned above stops blinking and that tells me that my laptop is now ready. I just tested my laptop startup and it took 9 minutes for my laptop to finish booting up (I am using my desktop for this message). You might want to DEFRAGment your Hard Drive, which should help, but this may take a few hours to complete depending on the size of your hard drive. If you have an Antivirus Program, it likely has a Performance / Maintain Computer option which should also help.
Jul 18, 2009 | Dell Studio 1537 Laptop Computer PC...
Start up with hp6325us
i think its the pentium processor had one a while ago with same problem , dont take my word for it though, just a thought
Mar 07, 2009 | HP Pavilion dv6325us Notebook
Computers & Internet Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
