Home | Transcend | (589307) Media | I have a 2GB sca...
Transcend Media
Problem for Transcend (589307) Media
I have a 2GB scandisk pendrive, I unable to format
By bhupeshchhn on Oct 22, 2009
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Solution #1
posted on Oct 22, 2009
Somewhat Helpful)
Geekman
Rank: Guru  Computer Accessories  Expert
Rating: 85%, 1679 votes
Try formatting the flash drive using this method.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Was this helpful?
Yes
No
Popular Solutions for Transcend Media
Questions and Unsolved Problems for Transcend Media
Do you recommend Transcend (589307) Media?
Answer
Answer
want to format sd card wit fat (fat12)can use vista windows 7 or xp. do you know of a program?
Answer
My Tanscend make pen drive, system files are washed out. How recover the system files
Answer
i purchase transcend pen drive of 4 GB but now its not working. I have life time warranty. how shall... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Transcend Media:
Top Removable Media Experts
Rank: Guru Guru
Solutions: 14780
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Removable Media Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
