Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Change Language on Brother MFC-215C
I brought a Brother MFC-215C Printer/Fax/Scanner when I was in the Netherlands only problem is it appears the only language setting on it is Dutch but I was told it could be changed. Does anyone know if this can be changed or if there is some kind of software that may be used to add a new language to the machine??
Any help appreciated.
PLEASE, can anyone be sure of the eeprom code for GB before I start the procedure, I tried to contact the hotline but I'm not sure of their phone number either.
Thanks for ur help
Posted on Jun 02, 2008
  • 832 Answers
So here you go:
1# Call brother hotline for info what is the 4 Digit eeprom code for England.
2# If you have the info (e.g. 0004 -> Check by help of brother hotline because I am not sure what code you need for GB!!!)
press menu then start bk copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press 7 then 4. You will see the dutch eeprom language code. Press the 4 numbers given to you by brother hotline. You should see the 4 digits. Press start bk copy to confirm. machine will return to maintenance.
press 9 then 9 to leave the mode. machine will come up again with english language ;-)
Posted on Dec 30, 2007
Change baud rate for brother fax
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
MFC 215C, mfc 215c erorr 46
most likely your flush box is full of ink, the pads will need to be replaced by a service center.
Apr 20, 2009 | Brother Multi-Function Center® MFC-215C...
My fax BROTHER MFC-215C does not print after RECEIVING. it also does not send fax after scanning.
The solution, finally, was very simple: To disconnect the mains voltage, for several days, from BROTHER MFC-215 .
After that, I was successful to receive and print the incoming faxes.
Thank you very much for your willing to help.
Mar 27, 2009 | Brother Multi-Function Center® MFC-215C...
MFC 210C All in one
i cant find the softwares of mfc-215c.i can only print but cant use scanner n other fitures in it
Oct 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-215c unable to clean?
The ink blotter in the bottom of the machine is full, this is a built-in redundancy. Machine needs to be completely stripped to replace this.
Buy another brand next time.
Oct 01, 2008 | Brother Multi-Function Center® MFC-215C...
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Mar 27, 2008 | Brother Multi-Function Center® MFC-215C...
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
1,858 people viewed this question
James Cagle
James Cagle
Jim Keysor
