Computer does not recognise device
When hooked up through USB port, windows does not recognise device. My system is running windows xp sp2, 512 ram. The unit works fine through my laptop running the same operating system and acts as a mass storage device. i can view and transfer files back and forth no problems. i try to connect my mp3 to my computer to charge or to download on to it but nothing comes up on the computer
    Uploaded 5 video answers.
  • 152 Answers
You may have to search the driver for it on the net..
open your control panel add hardware
or removeable see if xp can find it
Posted on Dec 30, 2007
USB port is not working
first check whether ur os is windows 98 or xp if it is 98 then for any device u need usb driver. if it is xp ten its ok. check the device manager whether usb driver is loaded in ur system. right click on my computer icon not the shortcut icon. then select mange then select the device manager from the option available on left hand side of the window. then check the usb section whether any driover is loaded into ur system. if not then install from ur motherboard cd. if that also does not work them u need a replace of the usb port.
tell me u have a error message window cannot recognise the usb. if this appears then it need a replacement of the port. thank u
Feb 25, 2010 | ASUS P5PE-VM Motherboard
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Mar 26, 2009 | Canon EOS 450D Digital Camera
No USB Controller tree in XP Device Manager
Windows operating systems include native support for devices and systems that comply with the Universal Serial Bus (USB) specification.
Click Start, click Run, and in the Run dialog box, type:
Do you see the first one? You can try and get it to update its drivers. if not, all USB drivers are in the service pack 1.
let me know!
Feb 21, 2009 | IBM NetVista PC Desktop
Operating system ex mce
Is this a USB connection? Try a different USB port. If it still won't work, go to: MY COMPUTER: PROPERTIES: DEVICE MANAGER. See what it says in there about USB DRIVERS and HARD DISC DRIVERS.
Dec 29, 2008 | Computers & Internet
Hi-speed USB device plugged into non-hi-speed USB hub
Hi Shiva,
Did you try to boot into your BIOS and check the settings for your USB port? Often you can set the compatibility mode there.
Secondly, try to connect the usb device to different USB ports on your PC, they might not all be connected to the same controller (front or rear for example).
Aug 24, 2008 | Microsoft Windows XP Professional With...
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
USB problem
i think u must upgrade the USB driver on ur pc go to this link and download the driver and save it in desktop and double click on it and install it
rate me solved if its help thx
Oct 30, 2007 | 2wire 1000-200004-000 Network Adapter
Hi I get this alla time I have a few links below that will help you with ya problem... have a good look at ALL of them. 255047.aspx DeviceDoc/51417b.pdf forumID=5&threadID=187166&start=0
Sep 05, 2007 | Audio Players & Recorders
125 people viewed this question
