Kenmore Oasis HE 27082 Stainless Steel Top Load Washer
Problem for Kenmore Oasis HE 27082 Stainless Steel Top Load Washer
My kenmore elite oasis washer will not drain or
By rnaoliver on Oct 22, 2009
my kenmore elite oasis washer will not drain or finish cycle
Solution #1
posted on Oct 22, 2009
Not Rated)
e-ware
Rank: Guru
Rating: 91%, 63 votes
Washing machines don't drain like a sink, there is a pump inside that pumps the water out at the end of a cycle, usually before the spin cycle starts. If the machine is not draining, there is a problem with the pump. Assuming you have an electric pump, either it is not getting electricity due to a defect in the timer or the wiring, or the pump itself is defective.
I don't know what your powers and abilities are, but if possible you can check for power using a multimeter. The pump will be located in the base of the machine, and will be connected to the outer tub with a hose. Turn the water taps off. Remove the power lead from the pump and cycle the timer by hand to see if power is coming to the lead after the wash cycle. If it is not, the timer is likely defective.
If you are getting power, the pump is defective. Depending on the manufacturer, sometimes you can get a repair kit for the pump, but practically your best bet is to go to an appliance place and get a replacement pump - they are common because pumps and timers are the most common machine failures.
Replacing the pump is usually pretty simple, and involves undoing screws for the most part. Just be aware that even in a machine that drains properly there can be up to a liter of water left in the pumps and hoses.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Was this helpful?
Yes
No
Popular Solutions for Kenmore Oasis HE 27082
Questions and Unsolved Problems for Kenmore Oasis HE 27082
Do you recommend Kenmore Oasis HE 27082 Stainless Steel Top Load Washer?
Answer
Answer
our washing machine kenmore elite stops spinning and does back to washing mode again. there is... (More)
Answer
my washer won't drain you can hear yhe pump but nothing happens
Answer
Oasis 110.273 "F1" error on inital and rinse cycle fill. Have already checked to make sure... (More)
Answer
I am experiencing the dreaded F1 error on my Oasis HE model 27082603 when filling. I can stop and... (More)
Answer
The washer kept going off balanced and showing UL. I could maneuver things around and get it to work... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore Oasis HE 27082...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
