Question about Konica Minolta DiMAGE G530 Digital Camera
Error system MF00C
The zoom don't want to retrackting or open correctly. It's normal when i put in the battery, at the biggining, but, after, blue screen with error message MF00C. What can i do ?
Thanck you
Dens denis.morgnieux@videotron.ca
  • calex060 Jan 08, 2008
    I had to replace the battery in my Konica Minolta G400 camera and the zoom was out when replaced (as I lost the battery when taking a picture) when I replaced the battery with a new one I have an error system MF00C message. How can I fix?
    Thank You
Just solved this problem on my Dimage G530. An earlier time the lens (inner part) was cocked to one side after a small drop. Pulling it back straight, out of the outer part, fixed it and the lens closed.
Then just this past trip, the lens was not retracting with the MF00C error and the lens looked straight. It had opened in a pocket and gotten bumped. I had even taken the case off but that did not offer any insight into fixing the problem. (They certainly cram a lot into the case). I was about to give up and just buy a new camera or was going to inquire at vistek to see how much it would cost to have it looked at this Saturday because I really like the camera. Anyway, to make a long story short. I decided to pull hard on the inner part to pull it out - basically try to cock it to one side then the other. The lens popped out to it normal position and now everything works fine. So it appears that if bumped the lens goes to a lock position to prevent any damage to the drive mechanism.
Hope this helps someone else with this problem.
Posted on Jan 23, 2008
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
The zoom did not operate normally insert the battery again and turn the camera on. if the camera does not op normally do not put excessive pressure on it and contact the service center i got this error...
The solution is very simple.
you are going to remove the battery (while this screen is on) as the command screen tells.
And your camera should function properly.
I tried it and it worked.
NB; Do not try to close your camera then remove the battery.
Remove it while the camera is still on.
Jun 04, 2011 | Samsung ES30 Digital Camera
I have a Fuji finepix j38. I went on the beach and it got a little wet and it wrote zoom error and now it isn't charging either.
Welcome to Fixya. Having a "zoom error" message is a camera malfunction, in this issue you can try to turn off and then turn it on again but this time you have to take care not to touch the camera lens or try not to blocked the camera lens while retrackting. If you still have the same issue you can try to visit this site for some steps you can do before sending your camera to your Fujifilm center.
In regards your issue about the charging of your battery,as you said before that you bought your camera to the beach. Try to clean the terminals with soft and dry cloth. Also, possible that the battery has reached the ends of its charging life. Purchase a new battery. If the battery still fails to charged, you have to contact your Fujifilm center.
Please let me know if you have any question.
Thank you for using Fixya.
seancarlisle
Apr 27, 2011 | Fuji Cameras
The problem is that the lens eont open and this system error mf00c appears all the time
A lens error can be caused by physical damage to the mechanism that controls the lens, or debris that is interfering with the operation of the lens.
This article may be able to help you with a "do it yourself" solution.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
In the event that your problem is due to physical damage and not just dirt or debris, you will need to take it to a local camera repair shop for troubleshooting-- though with most consumer digital cameras, labor and parts cost of a repair can easily exceed the value of the camera.
Mar 12, 2011 | Cameras
My hyundai MP 567 FM don´t communicate
if you put the old battery and it works properly then the new battery you bought is not the exact battery for your mp3.also i advice you to reformat your mp3
Feb 20, 2010 | Audio Players & Recorders
2003 lexus convertible retracktable antenna
always put those down before entering a car wash.
the auto parts store will have a cheaper one than the dealership, or try a salvage yard.
Feb 19, 2009 | 2003 Lexus SC 430
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Minolta G530 System error MF00C
Lens motor stalled - a repair is not likely Check out the Konica web site
Aug 03, 2007 | Konica Minolta DiMAGE G530 Digital Camera
Zoom error too
if you spill any thing, like a soft drink,tea,coffee,etc. anywhere around the camera, when the lens barrel is open, it will cause it to stick when it is closed. so when it dries, you are stuck. put fresh batteries in, and with a rubber mallet, lightly tap on the face of the lens, when the camera is powering-up. do not hit it hard. after two taps, my camera lens opened up. you can clean the barrel with some wd-40, with a q-tip swab. use very sparingly. and next time, be very careful where you lay-down your camera. you never know......
Jul 08, 2007 | Fuji FinePix A350 Digital Camera
Konica Minolta DiMAGE G530 Digital Camera Logo
406 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
