Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
Ultima wf840 leak
My washing machine leaks a small amount every time it is used, but I cannot remove the top to check anything!
Please help?
Steve
    Sergeant:
    Champion:
  • 262 Answers
Chance are the door gasket is leaking but I hate to tell ya you are going to have to take dryer off the top to get further in to the problem
Im assuming its the dryer or what ever has to be move to fix the leak and the only way is through the top SORRY
Posted on Jan 01, 2008
Hotpoint wf840 fault (F-02) please help do u know what tis means?
try checking motor - module connections -brush - tacho on the motor
Nov 04, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
My washing machine is giving me F-05 on the screen, it will not empty after the load has finished, please help (Ultima WF840)
Sound like your drain pump is blocked. Tilt the machine as far back as you can to access underneath. The drain pump is located at the rear corner. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima wf840 drum jammed display saying error code f 02 can any 1 help
Error F-02 is a slow drain problem. Undo and remove the wide tapering pipe from the bottom of the drum to the pump. Inside you will find a non return ball valve, clean this and your problem should be solved
Jan 08, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
H20 ERROR
This error means - Problem is in the inlet valve.
Your inlet valve at behind top of machine is defective or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem then you need to change inlet valve.
Good Luck!!
Thanks
Jul 24, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
WF840 is flashing H20 what is the problem
machine cant take in water, if you hear a quiet hum when a programme is started that will be the inlet valve opening, check the inlet hose isnt kinked, the water tap is on, on the isolator tap sometimes the little handles snap and you cant turn it on or off, remove the handle (littlwe screw on top) and turn it with a small spanner
Jun 09, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Test on washing machine
yes try pressing the on/off button and start/cancel button at the same time
May 26, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
all i can suggest with the info you have given, is to remove the lid and check for anything lose like the weight block etc also have you checked the inner drum for play, maybe the bearings have gone please not to all it is not safe to continue to run machines that are making noises, they can only get worse making more damage, what can start off as something silly can eventually write off the machine start with that and see how you go, glad to help, if i have helped please rate me
Oct 03, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
91 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
