Question about Jensen XA4150 Car Audio Amplifier
Problems with amp...
If the transistors are blown could it be posible to buy them and reinstal manualy? Or they can be reinstaled only in manufacter service?
    Scholar:
  • 198 Answers
If you have some idea about installation procedure it wont be a big deal to fix it by yourself
Posted on Jan 06, 2008
Crt standard hisense tv no power fuses are not open only switchmode transistor is shorted is that posible.
Sometimes is possible. Because, when the transistor shorts, the small value load resistor connected to its emitter might blown up before the fuse.
Sep 19, 2013 | Televison & Video
Playing too loud music has blown my amp
maybe because your amp is overload, try to load 8 ohms single speaker per channel, then try to playing loud, if blown your amp again, the power transistors bias maybe excess to 0.6V ' if transistorized, if IC power amp, check cooling fan.
Aug 06, 2011 | Denon Audio Players & Recorders
Solve Your ''kenwood kac x40m problems'' Problem Now! the operation protection light is on never goes off subs dont work what do i do
your amp output transistors are shorted and protection is activated to protect your amp from bigger damage.if you are confident you can try to open the amp and you should see some burn marks or burnt(blown) transistor and just simply replace him.or take it to repair shop
Mar 21, 2010 | Kenwood KAC-X401M Car Audio Amplifier
Usb & Front panel Problem..!
these front usb ports cause prob lem always kindly change the whole panel with usb ports in front they are faulty and giving problems and will create more problems if u dont change them kindly get new one u can find them easily on any store and simply chang them see the connector going to the motherboard plug it out and plu the new one at same location
rate me WELL !
Regards
May 23, 2009 | Gigabyte Computers & Internet
My canon i 255 is not ready. it is blinking green and orange. I have reset it manualy as wel as with genarel tool available in net. It is ok for some time but it is happening again when it is off for some...
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Office Equipment & Supplies
Amp turns on just fine but no sound comes out
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
I have an audiobahn a2300hct with blown components.
IRFZ48ZPBF-ND
^ from Digikey.com are a good replacement. You need to replace all of the Z48s on the side of the amp where the ones that failed were located. Digikey will also have the resistors. There may be other problems. If you're new to repair work, read through the following page.
Basic Amplifier Repair
Let me know if you have any other questions.
Dec 10, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Computer doesnt see router
first of all configure you lan card with ip address 192.168.1.2 or any other address given by manufacters. then ping 192.168.1.1 or given address in manufacter
go to internet explorer type http://192.168.1.1 or path given by manufacter is required to type there. press enter, one pop up window will appear give user name and password given by manufacter in the manual.
do the necessary setting in router then save and restart it
Jul 05, 2008 | Computers & Internet
Need a lil ore help!!!
If the overcurrent of DC offset lights are not green, the amplifier probably has blown output transistors.
To eliminate other problems, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally (all lights green), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 05, 2008 | Sony XM-2150GSX Car Audio Amplifier
Protection Light
This is almost always caused by shorted output transistors. To eliminate other possible problems do the following.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Generally, an amp with blown output transistors can be repaired.
Dec 27, 2007 | Boss Riot 850 Car Audio Amplifier
Jensen XA4150 Car Audio Amplifier Logo
74 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
