Question about HP iPAQ h6315/h6365 Pocket PC
Hp 6315 i bought never used hp6315 but there is problem. Not turning on. making soft reset and other aplication then may be turn on. After i left it aside then itself turn off and never turn on back. Battery is full.
  • Anonymous Mar 15, 2008
    My battery was flat and the phone doesn't turn on.
  • Steve
    Steve May 11, 2010
    My iPAQ 6315 will not go past the opening screen that says "tap screen to set up". I have tapped the screen, Hard set it, Soft set it, but it goes nowhere, Just stays on "Tap screen to set up"
    Once the "CROSS BAR" (+) came up and I tapped it, but it just stayed in the center of the window.
    Hope there is someone who can help me get it working again.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
It seems that either the touch screen got corrupted or may be the os of the pda has gone bad..
if required reinstall the os and then try
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 05, 2008
Samsung SGH a727 forgot password to turn on phone
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (10)
  4. Highlight, using the navigation keys, any of the following:
    • All: Phone, Display, Profile and Alarm settings will be returned to default values
    • Phone Settings: only phone settings will be returned to default values
    • Display Settings: only display settings will be returned to default values
    • Profiles: only profile settings will be returned to default values
    • Alarms: only alarm settings will be returned to default values
  5. Press the center navigation key to check the box(es) of reset settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is “00000000”
  8. Press the left soft key for Confirm
  9. Enter the password again to confirm, using the keypad
  10. Press the left soft key for Confirm
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Sep 25, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Tip
HARD RESET HP iPAQ h1900 Series 1910/1915/1930/1935/1940/1945)HP iPAQ h6300 6310...
While holding down the power button press in on the reset button (reset hole) with your stylus (located on the left hand edge of the unit rather than the bottom) for about 5 seconds.
on Mar 10, 2010 | Cell Phones
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
HP ipaq 6315 No power
Hello i'd be happy to help :-). Since you said that you bought a new battery and it still didn't work. I am guessing that you might have charged you Ipaq by pulling it into a regular wall outlet . This is bad because that outlet could send to much electricity into the Ipaq and can kill it. That might be the problem why your Ipaq is not working... I would recommend for you to call HP and see if you can return your Ipaq to them and see if they can send you a new one.
Jun 18, 2008 | HP iPAQ H2210 Pocket PC
Pin code
With the device powered on, press and hold the Left and Right Soft Keys. Whilst holding the Left and Right Soft Keys, perfrom a Soft Reset on the device by inserting the stylus into the reset hole on the bottom of the unit. If successful, you will get a message on the display of your device asking you to confrim the Hard Reset.
This should erase the lock code you are being asked to enter.
Apr 20, 2008 | HTC PPC-6800 Smartphone
HP IPAQ 6315 Auto Hard Rest
my ipaq6315 shutsdown and resets,i keep losing data...help me pls
Dec 04, 2007 | HP iPAQ h6315/h6365 Pocket PC
IPAQ 5455 Hard Reset
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Sep 07, 2005 | HP iPAQ H5455 Pocket PC
H2215 Blutooth Radio failed to turn on
The problem was in the HP ProtectTools security aplication. After disable the aplication and do a hard reset the bluetooth works. I had see that after the hard reset begins a process where some HP software are installed again. One of these software is the Broadcom driver of the Wifi/BT (You can see it for two seconds in the top bar). I think that the ProtectTools blocks some file upgrade (DLL, Exe, config file, etc.) that causes the problem. After solve the problem I have restored a full system backup done before disable the ProtectTools and do the hard reset, and all still works fine. I hope this can help you.
Sep 07, 2005 | HP iPAQ H2215 Pocket PC
HP iPAQ h6315/h6365 Pocket PC Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
