Question about JVC TH-S3 System
No colour when powerd up the picture is in black & white I have made sure it is not the connection to tv by trying composit & scart
  • Big Dave l Feb 14, 2008
    no colour just black n white pic . useing scart lead not composite can any 1 HELP PLZ... their has to be a hidden menu sumwhere ...HELP!!!!
  • georgei83 Feb 17, 2008
    went into setup menu on the tv, set the av channel to S-IN
    PROBLEM SORTED
    I am a silly boy !
Take the disk out. on the remote slide the bottom down. press and hold down the scan button 2 to 3 sces,then press right on the directional pad.your options is displayed on the machine
with disk i machine repeat above for brightness options
hope this is useful
bigdaveyl@hotmail.co.uk
Posted on Feb 14, 2008
Well most newer systems tend to use the green jack with others as well, as far as i know this only puts out black and white try pluggig it into the yellow jack on your tv insted of the green one posably it could be a filter built into the tv with the green jack( i hope this fixes the problem if not im sorry that i was of no help)
Posted on Dec 31, 2007
My TV rca model hd52w68 HV black in white Pict
I think you were trying to say you have a black and white picture(?) Make sure you haven't connected a composite(yellow) video source to a component (red/blue/green) connection on the TV.(If you connect a composite video to the green component connector,it will appear to be in black and white).
Jun 09, 2014 | Televison & Video
Hi, I try to connect my PS2 to LCD TV and its has no color. The TV is LG and I tried the with SCART and with those holes on the side of TV (yelow, red and white). The strange is that when I start the...
make sure to set input on the TV is set to s-video.
If left on AV2 the picture is black & white.
Set to AV2S the picture is in colour.
http://www.avforums.com/forums/ps2/692572-ps2-picture-black-white.html
here some troubleshooting steps to help find out what maybe wrong
1. try a different tv 2. if you have a friend with a ps2 try borrowing their cable to make sure its not the cable. 3. try your friends ps2 on your tv.
Jun 01, 2011 | Video Game Consoles & Games
Dear Sir My Dvl 919 dvd player component output give black and white images no colour but SVHS have color images.Pls advise Erwin Koh
there are three wires associated with "component output" .. those have to be hooked up to component inputs on your TV .. not to the composite video input .. if you do hook up to composite you will get only a black and white picture .. make sure all three wires are connected correctly then select the proper input in your TV setup ..
Jan 27, 2010 | Televison & Video
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
When connecting video or set-top box using composite video cable picture is black and white. If I use S-video I get colour. Video only has scart and tv only has composite/component/s video connectors so I...
you really cant convert to component. it defeats the whole purpose of upgrading your tv. with your tv you should be using hdmi to connect all your devices your cable box should deffinatly have one. any time you connect component to something else you will get black and white hdmi is totally digital where as component is still analog pluse you dont need audio cables with hdmi its just one digital cable
Sep 21, 2008 | Televison & Video
Trying to import analogue video from VHS
I _assume_ you're feeding PAL video into the MV500i... one of the simplest ways to lose color information is to feed an NTSC (or PAL60) source to a standard PAL display.
Another possibility is that you're losing the chroma signal. I believe this camcorder has a composite (CVBS) analog input. If you're tapping off a SCART connector, make sure you use a SCART to composite cable, not SCART to Y/C (luminance/chroma). Are you using the same cabling with the camcorder as with the TV?
Jan 19, 2008 | Canon MV500i Mini DV Digital Camcorder
My Plasma 42PD580DTA
I assume your DVD is coming up in colour when you plug it into a standard scart connector? Have you tried using a different S-Video cable because this sound symptomatic of a dodgy lead?
Check the SCART end of your lead for any bent or broken pins.
Failing that if the problem lies with the TV itself I'd really recommend having a pro look at it. Plasma's are expensive and opening it up if you don't know what you are doing is a bad idea.
Dec 02, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
My genisis has no picture!
the leads probably need replacing as these often split inside are you sure the your selecting the right setting on the tv are you using the colour leads red and white or is it scart lead ...............
Nov 19, 2007 | Sega Genesis 2 Console
Avermedia Averkey lite - Monitor Colour Display Issue
I had the same problem. I was going from PC -> Dvd recorder -> TV.
I had the S-Video output from the averkey going via an adaptor into the DVD scart input. I discovered a setting within the DVD menu which could select between 's-video' and 'composite video' on the scart socket. (it appears that scart can carry either/or, I guess).
I changed from composite to s-video, and I got colour.
I think seeing a greyscale image indicates that the signal being sent is S-Video, but the equipment that is recieving it is expecting composite video.
Sep 23, 2007 | Avermedia QUICKPLAY (pquickplay)
PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Jan 16, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
JVC TH-S3 System Logo
143 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
