Dell A940 All-In-One InkJet Printer
Problem for Dell A940 All-In-One InkJet Printer
Printer problem for a dell 924 printer
By moses_joshua on Oct 22, 2009
"cartridge stall" comes up when i try to print, whenever i try to print a box comes up that says that there is a cartridge stall
Solution #1
posted on Oct 22, 2009
Not Rated)
bschilz
Rank: Guru  Dell Computer Hardware  Expert
Rating: 87%, 676 votes
I have run across several Dell & Lexmark printers that after a while of working great, decide to have an "issue"... If you are printing more than 1 page, they will print the first page, then stop. The computer says "Cartridge Stall" and the printer says "Hardware Error 0502" or something similar, depending on the printer... Anyway, the message on the computer suggests making sure your cartridges are installed correctly, and nothing is blocking their path... After dealing with this many times, I have finally found a solution that seems to work!
There is usually a metal bar that the cartridges slide back and forth on... over time, this bar can become "gunked up"... Use alcohol pads to clean up the bar, and the surrounding area.... Clean out as much of the track as you can also. Tada... .No more cartridge stall!!
Was this helpful?
Yes
No
Popular Solutions for Dell A940 All-In-One InkJet
Questions and Unsolved Problems for Dell A940 All-In-One InkJet
Do you recommend Dell A940 All-In-One InkJet Printer?
Answer
Answer
Cannot install this hardware. There was a problem installing this hardware: Dell A940 An error... (More)
Answer
the code number on my fax is 0502 its a dell all in 1
Answer
I'm getting the blue lines over graphics when printing with Dell A940. Tried both cleaning and... (More)
Answer
when printer is turned on, it makes continous sound
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Orlando, FL
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
