Question about T-Mobile Sidekick II
Connectivity problems my sidekick 2 is not connecting to internet, instant messenger or emalis... and i have reception
    President:
  • 625 Answers
Check your data plan. Those 3 things not working is an indication that the data plan is not active for your phone. Call t-mobile to verify
Posted on Dec 30, 2007
My internet is on but each time i try to sign in to yahoo messenger it tells me there is problem with the internet connection
Maybe the problem is due to slow net connection. Goto Messenger->Connection preferences and select the radio button "connect via proxy server",under that select "HTTP proxy". Then in the bottom, select your Internet connection from the dropdown menu and press ok.
Then try signing in. Good luck!!!
May 26, 2011 | Yahoo Messenger
I canot log into yahoo msnger
there is some problem in yahoo network connection . you can reinstall the yahoo.
Mar 09, 2010 | Yahoo Messenger
I can't view others webcam on yahoo messenger? when I going to view always reconnecting? wot's the problem?
web cam can work due to 2 things:
1. they need to place invitation / permission settings
r
2. they need to have fine video update settings
so which is lack at opposite side, but there is another minor problem that is "checking of net speed"
Dec 17, 2009 | Yahoo Messenger
Cant login with my yahoo messenger.it says problem with internet connection but i already checked it and the connection is ok.help me how can i connect to my yahoo messenger.
cant login with my yahoo messenger.it says problem with internet connection but i already checked it and the connection is ok.help me how can i connect to my yahoo messenger.
Nov 15, 2009 | Yahoo Messenger
There was a problem signing into my yahoo messenger 81003005
exit your Yahoo! Messenger
disable anti-virus and firewall
restart Yahoo! Messenger and change connection settings :
1. Click on "Messenger." 2. Select "Connections".
3. Switch connection from “Connect directly to the Internet” to “Connect via a proxy server” or vice versa.
click "Apply" then "OK."
Sep 30, 2009 | Yahoo Messenger
Whenever I tried to login in the Yahoo Messenger, an error appears 81003004
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 10, 2009 | Yahoo Messenger
Sir i cant access yahoo on my system can you provide me any suggestion
I have 3 suggestions: 1. Go to Messenger>Connection Preferences> then, you choose either connection directly to the internet or connect via a proxy server, and then choose type of internet connection>OK>Sign in again... let's try this, may be you can solve this problem. OR 2. Check your internet connection, may be your connection encountered problems...or i think better you should check your firewall settings. I think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to sign in your yahoo messenger, check it out, may be it blocked your yahoo messenger from sign in. OR 3. Open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger again. I hope these can be helpful! Try these! Good Luck! Hope it was helpful!
Jun 11, 2009 | Yahoo Messenger
Error 81003002
You may be have 3 options to solve your problems:
Try this:-
2. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. OR
3. Open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
Good Luck!
May 30, 2009 | Yahoo Messenger
Internet connection.. using yahoo messenger messenger encounter connection problem. please check the network connection and then click "Try again". (81003004)
internet explorer might be offline... open iternet explorer and connect it to the internet... it worked for me
Jan 14, 2009 | Yahoo Messenger
T-Mobile Sidekick II Logo
77 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
