Cpu speed currently 1.8mhz spec indicates 3000+ msi k8t neo 2 can u set cpu speed faster?
  • johnboy1949 Jul 23, 2008
    Can you please tell me what is the correct speed to reset cpu speed for ASUS P4S800-MX SiS661 FX
  • 44 Answers
You do not mention the CPU name, but if the CPU is a Semprom 3000+, then 1.8Ghz is the correct clock speed for the chip.
The "3000+" is what is called a "performance rating" - It is NOT the chips clock speed in GHz.
Look here:
If you want faster, then you would need to overclock.
Posted on Dec 30, 2007
Necesito manual de instalacion de k8t neo-v
Follow this link;
Oct 01, 2012 | MSI K8T Neo-V Motherboard
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
Looking to plug in my main switch and need help with finding the right port(s)...only see one color coded set of pins available....
Open the link provided below by MSI;
Download and install Adobe reader to view manual.
Adobe Free;
Manual for K8T Neo-FSR;
Download the maual if needed. Open to page 2-20.
Use the manual to connect you're case wires to the motherboard. JFP1 provides power to Reset Switch, HDD, Power on switch and Power LED. Use JFP2 - connect internal speaker. (Bios uses this for POST).
Power On Self Test. If you use Adobe you can zoom in on pg. 2-20 which will help you connect each set of wires to their matching MB pins.
Feb 18, 2010 | MSI K8T Neo-FSR Motherboard
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
Msi motherboard for model k8t neo ms 6702
Its the model numbers that vary the most when looking for the manual. Click on the link below to open MSI download site;
While on MSI's site I searched for MS-6702 and left out the term, "K8T NEO". MSI provided the another link;
The model numbers K8T Neo-FSR and FIS2R, use the same manual.
See link;
K8T Neo2-F and FIR use the same manual.
From the pic included, Connect everything to JFP1. Connect the speaker to JFP2.
b972b2a.jpg Wire colors do vary from case to case. Normally solid colors like red, green, blue and dark blue are used as positive. White and black are negative. Each jumper pair will share a common color. That common color is negative except when hooking up the speaker wire. Black is used for negative.
Oct 24, 2009 | Computers & Internet
I accidentally hit F11 Flash memory when restarting my PC that has an MSI K8T Neo motherboard and now there is no action or display - how can I restart my PC?
For that pull cmos cell from motherbord for 10 minutes so all settings are defaults.CMOS cell is round cell on motherbord.
Refix RAM memory.
Then check .
Let me know if you need more assistanse.
Sep 26, 2009 | MSI K8T Neo-FSR Motherboard
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
Upgrade sata hard drive
I Recommend Western Digital (W.D) Hard Disk Drive.
Comments pass......
Computers & Internet Logo
440 people viewed this question
David Payne
David Payne
