Question about Cameras
Dark screen when i turn my camera on the screen is dark,i know its something inside because when i look through lens opposite way can see the inside lens doesnt click open now and again it does and i can take a pic but most of time its not please help,this only happened overnight was ok the day before its a vivitar vivicam 3830s
  • bbddenny May 11, 2010
    My screen turns from dark to the Gray-Blue with the power button, but no image from the lens shows up. Batteries are good.
    Genius:
  • 2,985 Answers
Two reason for the screen to be dark
1. If you can see 'shadow' images on the screen, this implys the backlight tube or the inverter circuit has blown.
2 If No images show up at all then this is a mainboard failure
This is assuming the batteries are ingood condition and the camera powers up..
Check Vivitar support for repair/replacement options.
If under ewarranty it will be replaced
If out of warranty - New Camera Time
Posted on Dec 31, 2007
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
Dark Viewfinder. The image results are dark too. It's been like this for two days. And I swear I did not do anything wrong. :(
If the image results are dark, the problem must be inside the camera. If you changed the lens something fell inside it and is blocking the light to the camera. You should check your nearest Nikon store and get it fixed because if you try doing it yourself you could damage the sensor permanently and destroy your camera completley.
Dec 28, 2012 | Nikon D40x Digital Camera
Upon turning on my Nikon P100, i hear a clicking noise, and then there is a dark crescent shape on the right side of the screen, and then, the aiming reticle is to the right until i zoom in fully, at which...
Without seeing it myself, it sounds like it's the aperture inside the lens that is stuck at an angle. Unfortunately the only solution is to replace the lens assembly. Check with Nikon to see if you can get an estimate, I know if you send it in you can get a free estimate and refuse it if it's too high and they will send it back at no charge.
Thomas
Sep 07, 2011 | Nikon COOLPIX P100 Digital Camera
Aloha, My Lumix DMC-TZ3 is having issues. When I turn it on it is extremely dark. It's almost as if the camera is only registering one side of the color spectrum. Even the pictures that are taken come out...
Unless the protector blades on the front of the lens aren't opening fully, this doesn't sound like a lens problem. It sounds more like a sensor problem. Reset is accomplished by going into the menu and finding "reset"...follow the on-screen instructions. If you can't access the menu, do this:...remove the card and battery...press every button...leave it alone for 20 minutes...insert the card and then the battery...turn it on. I don't hold out any hope that either of these resets will do much good if this is indeed a sensor problem. When you say the pictures are also dark, do you mean when you try to view them on the camera screen or when you download the pics to your computer. If they're ok on the computer, then the problem is your lcd screen.
Jan 17, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
I have a 50 in RCA older HDTV that is experiencing a darkness in a V pattern starting in the middle of the bottom of the screen. I am told that it is not the bulb but possibly a circuit board? HELP
i have seen a few of these and not seen that cuased by a curcit failure.(OF coarse nobody has seen it all) I would suspect something in the optical path. what i mean by this.... the bulb shines light through a color wheel into the engine then through a lens bouncing off a mirror then on the screen. now is the picture visable through the dark area? their could be something inside. blocking the lens(dirt,bug,fly) or there might be a broke mirror. also the screen could of got wet and damaged.. dont know exactly but these are my best guess without seeing the picture... let me know how it goes
Oct 22, 2010 | RCA HD50LPW175 50" HDTV
My camera screen goes white everytime i turn on the camera
I Havee The Same Problem And Ive Been Reading Around And The Most Decent Answer I Found About What Was Wrong Was That Something Had Just Come Loose Inside So That Might Help Because Something Wiring Upo To The Screen Might Be Loose Its Worth A Shot.
Jul 26, 2009 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Dark circular spot on Ricoh R6 screen and images
There is a spec of dirt that made it inside the camera and has landed itself on your image sensor.
If you take a picture and the image has a spot on it, it could be the screen. If you transfer it to your computer and the spot is in the same spot, its something on the image sensor. You would have to send it out for cleaning, and a new camera would be cheaper.
Mar 30, 2009 | Ricoh Caplio R6 Digital Camera
V570 Dual Lens, will not switch to ordinary lens.
Hi, My V570 works fine on widescreen lens (the default on startup) but when I zoom up to switch to the other lens it goes to a dark blank screen and will take a similarly dark blank picture. I can hear the zoom activating as I click it so I think that is ok. I opened the camera
Jun 10, 2008 | Kodak EasyShare V570 Digital Camera
Black screen on LCD and in the eyepiece
Your camera is a reflex camera, it means what the lens you see If the displays are black it means that there's a block inside the lens, probably the inner mirrors are stuck. Try resetting the camera. Save the photos on the memory disk, disconnect whatever can be disconnect, get out the batteries, and let the camera rest for a day or two If the problem haven?t been solved and you don?t have the knowledge how to open the camera take it to fix, hope the insurance is still good. Good luck
Feb 23, 2006 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
326 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
