Install anti-f-commwarrior, then launch it.
Use this removal tool then do a full reset to your phone. Also, format your memory card.
If the bluetooth is not detected on the menu the fault is on the software or even a fault on the hardware. If there is no activation of the bluetooth perhaps the phone needs a rebooting . now it is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. See if the bluetooth is detected on the PC. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
