Home | Reddy | Heater-30-55,000 BTU Variable | I have a 55,000 hea...
Reddy Heater-30-55,000 BTU Variable
Problem for Reddy Heater-30-55,000 BTU Variable
I have a 55,000 heater glow plug come on then
By tedwilliamst on Oct 22, 2009
I have a 55,000 heater glow plug come on then motor turns on won't start not getting fuel what to do?
Best Solution
posted on Oct 22, 2009
Helpful)
dmftrucker
Rank: Guru
Rating: 87%, 402 votes
does the pump itself run or is the fan and pump run together, if this is the case, you may need to open the nozzle on the pump outlet and prime it (force fuel thru) the lines, the pump may have dried out, also check the fuel supply filter for restriction
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Reddy Heater-30-55,000 BTU
Questions and Unsolved Problems for Reddy Heater-30-55,000 BTU
Do you recommend Reddy Heater-30-55,000 BTU Variable?
Answer
Answer
The heater starts fine, but the gas flow is significantly reduced after a few seconds. Tried a... (More)
Answer
Tries to fire but shuts down after a few seconds. I have already ran it a few times this week. Now... (More)
Answer
Turns on with flame and fan and after 5-10 seconds shuts off. When I plug it in again, the same... (More)
Answer
my heater will fire up and run then if i unplug it and plug it back in the motor spins slow and the... (More)
Answer
55000 btu kerosene heater I ran great until i moved the heater to another room, plugged it back in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy Heater-30-55,000 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
