I plug the sandisk in to the computer & it doesn't light up nor make the noise. I plugged another one in just to make sure it wasn't the USB drive, the other one worked like a champ. What do I have to do to recover the picture from that drive? any direction would be appreciated.
kindly go to control pannel and and see that removable media device is configured and also check the drivers for it in device manager to ensure that fault is not on sofware end ,if this does not show and green......then try changing the port you insert it into hopefully this will fix the issue else consult local hardware shop for recovery of the data in it and also get it replace if under warranty
thanks and regards
kindly rate this solution
Was this helpful?
Yes
No
Popular Solutions for SanDisk Cruzer Micro 8GB USB
Sandisk Cruzer light does no appear and i have tried it on another computer and sill nothing is...
(More)
Sandisk Cruzer light does no appear and i have tried it on another computer and sill nothing is happening what do i do???
