You need new scanner section but try first to clean this one.Disassembly the printer and pull out the scanner section.Open it cover and inside you'll see the mirrors.Clean the ash from mirrors using cloth which leaves no hairs. WARNING! If you don't have a technical skills don't try to do anything. If this not help you need to replace the scanner section.
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet 6110 All-In-One
how to remove the inkjet cartridge and replace it. I have opened every place i can find - short from...
(More)
how to remove the inkjet cartridge and replace it. I have opened every place i can find - short from removing screws - where is the inkjet cartridge?
When trying to send a fax from an HP 7410 all-in-one all I get is communication error 421 or 242....
(More)
When trying to send a fax from an HP 7410 all-in-one all I get is communication error 421 or 242. What does this mean and how do I fix it?
My HP office jet 6110 - on power up the scanner moves to the right and causes the cogs to grind,...
(More)
My HP office jet 6110 - on power up the scanner moves to the right and causes the cogs to grind, this prevents the printer from doing anything else - I have tried cleaning the scanning glass as per another forum suggestion but this has not cured the problem - any help greatfully received.
On power up the scanner keeps trying to go to the right and makes a grinding noise - it is stopping...
(More)
On power up the scanner keeps trying to go to the right and makes a grinding noise - it is stopping the whole printer from working
