Question about Sharp CD-DVD500 System
I have a sharp CD-DVD500 sn#10822726 src that keeps displaying ER-CD20
As described I am receiving the ER-CD20 when I am in DVD/CD mode and I attempt to un-eject the tray? I was having other problems but right now this is the only one. What does this error mean, and what can be done to fix it? thank you for your help ^-^
SOURCE: unable to eject cd-dvd
unplugging the unit and then plugging it back into the wall outlet.
Posted on Oct 04, 2008
0 characters
1 Points
How do i conect supwofer out put ?
You need a mono RCA subwoofer cable (
Down where the speakers hook up to the rear of the unit there is a subwoofer output RCA connection. Plug RCA cable in there and run it to the Input of the powered subwoofer.
Mar 01, 2015 | Sharp CD-DVD500 System
Why does my sharp cd-dvd500 shut off when too loud? How do i fix this?
Hi, you like your sound loud like I do-to prevent the stereo from shutting off simply turn the " BASS " control down a little- 1/3 to 1/2 of full should do the trick, write back to let me know if this helped, good luck and thanks for asking FixYa-Prodzilla.
Apr 20, 2011 | Sharp CD-DVD500 System
How do I shut off the parental controls on my Sharp CD-DVD500?
With a disc in the drive press SETUP whilst holding down the SHIFT.
Using 0 - 9 Buttons eenter the 4 Digit Password ( - - - - changes to * * * * )
You have 3 attempts to enter the password ( Default Set at 0000)
LEFT and RIGHT to change parental level
DOWN to select CODE and the LEFT and RIGHT to select the desired Country Code
ENTER to confirm setting
Apr 15, 2011 | Sharp CD-DVD500 System
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
Jan 15, 2011 | LG HT303SU Theater System
The screen keeps flashing rear chk and the rear speakers are not making any sound.
I had the very same problem, and found that if you power up the receiver in DVD/CD mode, or tap the function button to display DVD/CB mode, the Wireless Rear Speaker AMP will automatically recognize and turn on the sound. This work around was not posted anywhere in the manual, just 1 of many workarounds I have had to put up with this system to work. Right now my fan went and it just keeps shutting down, I have had this system for about 15 months and very disappointed with the quality. My DVD player stopped working a few months ago, so now the system is rendered useless, not even sure it is worth fixing at this point since it is no longer under warrenty.
Jun 29, 2010 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Cd/dvd not working or showing on display cd won't eject
Okay, Fist I need to know the make and model # of your cd/dvd player in order for me to help you and what is it hooked to exactly as it is now.
I think I may be able to help you on this one =)
Nov 10, 2009 | Home Theater Systems
Sound problems/ receiver
NO., it cant be played thru both when it is in cd/dvd mode because from manufacturing it vl be like that. it cant give its sound to other when in cd/dvd. how am telling is i have YAMAHA yht-165. when i use dvd mode.. the sound wont get thru its output. only works when its in other modes like tuner, md-r, tv, aux.
Jan 26, 2009 | Samsung HT-DS610 System
Unable to eject cd-dvd
Oct 04, 2008 | Sharp CD-DVD500 System
Sharp CD-DVD500 System Logo
Top Sharp Home Theater Systems Experts
Sudeep Chatterjee
Sudeep Chatterjee
Josh Whitehead
Josh Whitehead
Are you a Sharp Home Theater System Expert? Answer questions, earn points and help others
