Question about Janome Memory Craft 3000
Thread keeps breaking
Hi I have not had the machine for very long Janome memory craft 3000 and I am having trouble with the upper thread breaking constantly
It appears to be looping before it breaks goes clunk and snaps
I have tried changing the needle adjusting tensions you name it
driving me mad
Lauren
  • rajpeat Dec 30, 2007
    Thanks I will take this advice on board
    I think I have a few things to check
    another suggestion was that the thread should be janome top and bottom not inferior threads
    what do you think?
    Also does anyone know how the automatic thread cutter is supposed to work
    Sorry about this but it was an early Christmas present and I am keen to get into it
    Lauren
  • rajpeat Dec 31, 2007
    I have solved it!
    I bought good thread and new needles
    Problem solved thank you all so much
    I am in embroidery heaven
    Lauren
    Guru:
  • 1,894 Answers
Try lubricating parts.
Posted on Dec 30, 2007
  • dewan nafees ahmed Dec 30, 2007
    ya. try using good quality threads and do read the manual in detail. it is much more help full.
    don't try to experiment before reading the manual. thank you.
  • 1,113 Answers
Here is the Manual see page 41 for trouble shooting
Pages 9 to 14 to ensure correct thread procedure
and check pages 17, 18 re correct thread tension
and make sure you have folled maintence guidlines on page 40
S.
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
My memory craft 350e won't keep the tension tight. What can I do to fix this? Please help.
Balancing Thread Tension - Janome MEMORY CRAFT ...
www.manualslib.com > ... > MEMORY CRAFT 4900 QC > User manual
Janome MEMORY CRAFT 4900 QC Manual Online: Balancing Thread ... Auto-threadtension When the thread tension dial is set at AUTO for ... to increase the threadtension. ... Sewing Machine Janome Memory Craft 350e Instruction Book.
Sep 19, 2015 | Sewing Machines
JANOME 300E thread jamming & breaking when embroidering over previously embroidered section.
It's too thick in that area. this happens sometimes when you get designs made for one of the larger or professional machines. Not much you can do unless you have a digitizer and can reduce the amount of under stitching.
Sep 27, 2013 | Janome Memory Craft 3000
I am having trouble with applique on a memory craft janome 4800.
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
check for burrs on the needle plate & on the bobbin case
May 02, 2012 | Janome Memory Craft 4800QC
I have a Janome Memory Craft 3000 sewing machine. It suddenly started skipping stitches. Now, after cleaning out the lint as well as I could, the machine will not pull the bobbin thread up. Any ideas?
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
Jun 28, 2011 | Janome Memory Craft 3000
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
How to thread janome memory craft 3000
I was wondering if there was a threading guide on the machine itself with number steps impressed into the white cover. They are not very obvious but may help. Also, try you-tube for a bit more information; good luck
Jan 09, 2010 | Janome Memory Craft 3000
Top thread breaking during sewing.
your needle needs to be replaced and make sure it is in correctly..if this does not work you will need to make sure your thread is not old. then adjust you bobbin tension...there are 2 tensions on machine top and bobbin
May 22, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
278 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
