Question about SanDisk Sansa e260 MP3 Player
Blue screen I connected my sansa e260 to my laptop to take songs off of it. When I disconnected it, i noticed that it didn't turn off and it just has a plain blue screen with vertical darker blue parallel lines. The wheel isn't blue, nor does it light up when i spin it. Also, when I hit or hold the power button it doesn't do anything. Is there a special combination of buttons to hold to restart it? If not, how do I do that?
Remove your back plate and slip the battery out for a second. Should clear it right up no problem. Next time make sure to close programs that might be using the device before unplugging it.
Posted on Dec 31, 2007
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Half of song list not recognized by Sansa e260
i will surely help you. you have mentioned that you can see all the songs when your mp3 player is connected to the computer. so what you can do is, you can very well go ahead & format all the songs in your mp3 player using your computer. then you transfer a few songs to your mp3 player(the songs which were not getting recognized in your mp3 player). this should solve your problem.
Oct 29, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
Deleting songs
Not exaclty, deleting songs has to be done when recharging through the usb port on your pc or laptop.
Once connected you should see and icon or folder(Sansa E260) pop up on you desktop representing your player which can be opened and contains your playlists, individual songs, and any media you may have transferred.
Within this window you can move songs, edit lists and if necessary delete any unwanted items.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 sync problem
Reformat and get the latest firmware upgrade from Sandisk
May 29, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 Car Connection Problem
Since I haven't heard back, I am going to clear this from my queue
May 16, 2008 | SanDisk Sansa e260 MP3 Player
Stuck in language mode
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
Connection screen
Reset the player - manual has instructions
Remote possibility:
Use the Thumbwheel to rate the song (1 to 5 stars) then press
|<< button to return to Music Options menu. My Top Rated
Songs can be viewed in MUSIC menu.
Dec 26, 2007 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 problem
It might just need to be reformatted. If you don't care about deleting and redownloading everything with songs and videos and pictures, too, then reformat it. Just plug the mp3 player into your computer and right click on the icon in the MY COMPUTER window, and click on FORMAT. It should come to a new window and click on start format. If this doesn't work, then call me to help you any further. Ask for Maxwell at 1-(239)-945-0583.
Jan 01, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
