Philips 42PF7220A 42 in. Plasma Television
Problem for Philips 42PF7220A 42 in. Plasma Television
NO Picture and red light blinks 7 times.
By jc3weeks on Oct 22, 2009
Best Solution
posted on Oct 22, 2009
Very Helpful)
stampco8
Rank: Wiz
Rating: 95%, 57 votes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Philips 42PF7220A 42 in.
Questions and Unsolved Problems for Philips 42PF7220A 42 in.
Do you recommend Philips 42PF7220A 42 in. Plasma Television?
Answer
Answer
my TV just went black and the light by the power flashes red why?
Answer
Same red lights blinking. I have removed the back, but suspect capacitors show no visible damage.... (More)
Answer
Green power light on but telly not on as regards main power or picture.Turn off on mains socket,... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , PA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
