not all the time i think you can access the menu by pressing both of the volume buttons together at the same time or the channel buttons together at the same time...its one of those and then you can navigate up and down by those buttons as well
i have a sony kp-53s35 and the picture is not in sharp nor colored. but it does show a picture. you...
(More)
i have a sony kp-53s35 and the picture is not in sharp nor colored. but it does show a picture. you can tell what is on but, like red looks brown blue looks grey, and fixing the color, sharpness, and the hue does not fix it.
when i turn on the tv the timer button starts to blink and it makes a noise every once in a while....
(More)
when i turn on the tv the timer button starts to blink and it makes a noise every once in a while. the tv sounds as if it turns on and then it has a black screen and i cannot hear anything. but the tv turns on and the remote works.
i was watching tv today and the screen and sound just turned off, i have the back of the tv pulled...
(More)
i was watching tv today and the screen and sound just turned off, i have the back of the tv pulled off so i can see inside but i have not touched anything, when i try to power on the tv the red light on the front just blinks, is there a fuse or something that i can check on
Started smokingfrom the I would call it the motherboard.and screen is blank.What would be the...
(More)
Started smokingfrom the I would call it the motherboard.and screen is blank.What would be the problem and how do I fix it?
Sony KP53S65. When unit powers on the sound starts up but the picture takes longer to display. The...
(More)
Sony KP53S65. When unit powers on the sound starts up but the picture takes longer to display. The picture then blinks on and off periodically for a minute or two before it remains on and works properly. The picture tint seems much redder than usual, could this have something to do power up issue? I opened the unit and vaccuumed/blew out all the dust, windexed the tubes and mirror. I then turned it back on with the back open and looked into the tubes while it was on. The Red and blue tubes have a clear image however the green tube image does not look nearly as distinct as the other two. Picture is crisp and sharp once it stops blinking except for the reddish tint. Could this all be the result of one problem and if so what do you think it is?
