Question about Spectroniq PDV-808
PDV-808 Disc Not Spinning
The unit is new. I set it up and removed the sticky tape from under the laser reader, as directed in the instructions. When I put a disk in, it makes noise, but the disc doesn't start spinning. Eventually, I get the "no disc" error message. Any ideas? Thanks!
  • Overdrive Jan 01, 2008
    That sounds right. Where would you take it to be fixed? Thanks so much for replying.
  • chambers33 Oct 04, 2008
    I have the same problem, I load disc and it makes a terrible sound, drive will not turn. I've tried removing the tape under the main disc, but.....
    Problem Solver:
  • 16 Answers
Can you see on the optical lens if the lights goes on.. if the red lights on.., problem is int he flex cable/cable wire/ or what so ever term use by the manufacturer.. posible also defective optical lens. or try to re adjust the trimmer on thier circuit.. tnx
if problem persist desame you may contact to the qualified technician.
Posted on Jan 04, 2008
There is a noise when the dvd is spinning and the unit does not read the dvd.
What is the brand name and model number to your DVD player? Provide more details, please. It disc spins, and the set doesn't read it, replace the laser pickup unit along-with its connection cable[flat]. If you wish to get some details, check the site linked here. Pull up older posts. Service manuals are in PDF, and cannot send by this window.
Dec 07, 2013 | Durabrand Televison & Video
DVD player loads then stops and says no disc, havent used it in about 4 years ,how do i get it to play dvd, tried to set up like it says but must be doing something wrong
Tries to play more than one DVD disc.Tries to play many DVD disc should be original DVD disc ok no DVD+R copying disc ok.If ur are still getting signal just saying loading signal awhile than say no disc show up, and u did playing it with many dvd original disc.Than the DVD player laser eye reader could be ditry.Tries websites like Amazon.com,Ebay.com to buy a DVD disc set that said like DVD players lasers eyes cleaners.Used it as directions said,if u still getting the same result mean ur DVD player laser eye reader it is dead,not worth repairing the DVD player if the DVD player laser eye reader it it dead,because the laser eye reader it is 90% important to the DVD player unit and the cost of it by replacing it will cost the same as a new DVD player unit.
Aug 29, 2011 | Polaroid 7'' Portable DVD Player
Even after cleaning the unit - it still states that there is no disc in the unit. What can i do?
If you see the disc spinning, but it is taking far too long for the drive to read it, it means the laser assembly has either failed or is failing. If you do not see the disc spinning, then the spindle motor is shot. You can observe the behaviour of the player with the top cover removed; but DO NOT look directly at the laser while doing so; even if it is faulty - it can still emit a radiation beam.
I don't think this would be an economical repair; it could cost more than it's worth for a workshop to replace the faulty parts and align them, plus they might need to upgrade the firmware. It would be cheaper to replace the whole player with a new one.
As products become cheaper to buy new, older models are becoming increasingly expensive to repair.
Mar 06, 2011 | LG Televison & Video
My daughter's player says no disc when we attempt to play a DVD. We have had the unit for a little over 2 weeks. What can we do to fix this?
Still under warrenty exchange for a new one or getting it warrenty repair.Happen to all DVD Disc?If some disc only,disc might have scatches,cracks or dirt or grums on it prevent the laser eye from reading it.The DVD player might have dirty Laser bubble eye reader.Tries take some Q tips dipping rubbing alcahols clean the laser bubble eye reader.
Jan 11, 2011 | Durabrand DPX3290L Player
The disc won't spin
Hi, It could be one of 2 things, either your laser is on its way out or the motor in the dvd drive has run out of lubricant. The latter is quite obvious as the drive will be noisy when spinning!!!, if ur tech savvy and are capable of doing so, remove the drive from the xbox and open up the drive casing, the motor is situated under where the disc sits on the little black disc.
There are 3 screws holding the motor in place, remove them and with gentle pressure pull the black section from the motor, clean thoroughly then place a couple of drops of wd40 or three in one oil onto the shaft. Re-assemble and that should fix your problem.
Apr 12, 2010 | Sony PlayStation 2 (PS2) Console
It says no disk.. and disk is not spinng..
If the disc is not spinning when you insert it in the player, then the problem is that the spindle motor has malfunctioned. The spindle motor is the device that spins your disc so the player can read the disc.
In the picture above you can see the optical reader lens (small glass bubble looking component) and the top of the spindle which the disc sits on (large circular component) and the motor is located directly below that.
The good news is that the spindle motor's average cost is between $25-40 dollars. The bad news is that if you can fix the problem yourself, you will need to remove the entire optical laser assembly in order to replace the motor its self and is a pain. You can have a service technician fix it for you, but the cost will now average you $80-100 dollars depending on what service charges are in the area you live.
I would suggest that you remove the cover and visually confirm that the disc is not spinning, just to make sure. You can try buying a can of compressed air and cleaning the inside out really well first because there could be dust build up which could prevent the spindle from spinning properly.
If you see that it is spinning up, then you may just need to clean the discs or the optical lens. You can take a look at my tips and tricks in my profile for instructions on how to clean the optical reader lens. I wish you the best of luck in fixing the problem.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Jan 31, 2010 | Philips DVP5990 DVD Player
Broken disk lid
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
Nov 06, 2008 | Spectroniq PDV-808
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mark
Mar 02, 2008 | Coby TF-DVD7100 Portable DVD Player
Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Jun 20, 2007 | Polaroid PDM-1058 Portable DVD Player
Spectroniq PDV-808 Logo
102 people viewed this question
Top Spectroniq Televison & Video Experts
Steve Allison
Steve Allison
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
