SOURCE: My kiddie carbon monoxide detector keeps giveing 4
May need battery replacement. These beep when it needs change of battery. Could also be broken, i had one that kept beeping on and off no matter how many batterries i changed. These break easy when dropped. Check if it has a warranty maybe it can be replaced.
SOURCE: why will the detector go off in middle of night no
these units will get dusty after awhile and unsually with either a vacuum or air in a can blower, you can clean the sensor inside, are you having any power blips?
worse case is just replace them
SOURCE: My alarm and smoke detector keeps beeping a single
Ours keeps chirping even after we replaced the battery. I'm not sure how to fix it.
We are going to try and clean it but if it keeps doing it after that then I guess it means it needs to be replaced, right?
SOURCE: i have kiddle nighthawk detector
1) Does the display show "Err"? 2) When you press and hold the Peak Level button does the display change to "E09"? If so, then you have just been "had" by the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of them to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy. If it is still under warranty (5 or 7 years depending on date of manufacture) they should replace it. In any event, buy another one; if they replace your first one you will have twice the protection. Not a bad thing.
